In Search of a Colorado Springs Mechanic
310 Views 2 Replies 3 Participants Last post by  IronLungZSTI
Hey folks, I'm in need of an oil change and a check up from a professional in Colorado Springs (or nearby) on my 07 STi. It has been running 10-15 Degrees (F) warmer than usual on its coolant temp and has been throwing a Check Engine Light with a code of: P0328 (Knock Sensor 1 Circuit High Input). Any advice and/or recommendations for mechanics in the area are welcome!
1 - 3 of 3 Posts
I would flush the cooling system, change the thermostat, back flush the radiator fins with air and or water and you probably just need a new knock sensor...am in the albuquerque area if you feel up for a drive!
TGA Performance or Revolution Performance are both great Subie shops
1 - 3 of 3 Posts
