1 - 16 of 16 Posts
Just wanted to share a trick I thought of, I put some ice cubes in the water tank for the IC spray just to cool it down a bit more. It worked pretty nice, not too sure if it gives you any extra ponies. You guys should give it a try.
I don't believe cold water from the intercooler spray box will make much of a difference. Think about that water travelling down the tiny hose all the way to the spary nozzel. By then it would probably not be cold or you might have to hit the button 10 times to acutally get colder water to the intercooler. Wouldn't the main cooling effect of the spray be via the latent heat of evaporation which would far outway the actual temp of the water (ie. if you jump in a hottub and then stand in a 50mph wind, you will feel rather cold due to the latent heat of evaporation)
Thanks
Anyone tried dry ice directly on the intercooler for something like an autocross? PErhaps this with water spray to sublimate the dry ice would really cool off the intake charge.
· Drive True
Re: people's reaction to your STI...
My gut instinct tells me this would be bad since dry ice produces carbon dioxide, which is heavier than air, but more importantly, not combustible. Not to mention that it might damage the vanes cuz it's too cold...
Discussion Starter · #12 ·
Hmmm, I put ice in mine on nights I'm out "playing around". I believe it does make a differance. When spraying the I/C with ice water it does stay very cold to the touch. When I don't use ice the I/C just feels wet.
thats what i did. if you press the spray enough times you can pump the cold water to the ic. I tried it and put my hand in the scoop to feel the spray and it is colder. Not too sure how much it helps but oh well, I had fun.
1 - 16 of 16 Posts
