Well a month after I had the oil changed on my STi at the dealers I decided to check on my plastic undertray to make sure they didn't cut it. Now I thought everything was good till I saw a thread on NASIOC about this happening so I decided to really check. As it turns out it looks like they did cut a section out of my undertray. I would really appreciate it if someone could confirm it for me whether or not this could have been done at port.
Now the cut is right next to the oil drain plug. It looks like there should be a hole in the undertray that allows me to access the drain plug. What I have now is the beginnings of a hole with the outer ring cut out so now it is a recessed cut in the undertray. I can clearly see that the outer loop of the original hole is gone. So I'm asking if it is normal to have a hole around the drain plug or a recessed cut instead.
I'm going to be making a call early on Monday to hopefully sort this out.
Thanks
Thanks
