1 - 11 of 11 Posts
Can everyone that has an STI do me a favor? On the windshield wiper column, there are two extra options. One is where you push in the button and it sprays a blast of water and swipes the blades about 3 times. The other is when you pull the stick towards you (The stick says "Mist") and, according to the book, it will spray and swipe for as long as you hold it. My civic was exactly the same way. Problem is that when I pull it towards me, nothing happens. Is mine just wired wrong or something?
Discussion Starter · #4 ·
Maybe I just read the book wrong then. I am going to go recheck it. For all I know, I might be confusing the way my Civic worked as well (i.e. whether I was pushing a button or pulling it towards me). Good to know that it isn't just me though.
So then, Brandon..., does that mean that "your stick isn't squirting like it should"???
*tesingly*
Same thing happened to me on my WRX I was on the way to the dealer when I discovered that you just need to keep pumping it until the water comes out of both. It took quite a few pulls to get it to squirt. No porn star pun intended. :p
CoreySTi04
1 - 11 of 11 Posts
