1 - 4 of 4 Posts
I want to do my own amp install. I have a couple of questions; Can I run the power wire on the driver side? I have only seen pics of the passenger side. The only reason being that the battery is on the driver side. Also what gauge speaker wire to use? Another thing that worries me is the crimp falling off the 2 gauge power and ground wire.
Please post pics of how to remove moldings and such to run the wires.
So Gangster It Hurts
Mine was run down the driver's side. . . no problemo. :p
Removing the moldings is pretty straight-forward. Just a matter of pulling them off and being mindful of the clips. I'll have to take a closer look, but it's a lot like my last car (Honda) . . . they're pretty easy to disassemble. :D
I did the same thing. It took a few wire tyes and you get to see that there is NOTHING, but sheetmetal under the carpet. Just use a fast acting fuse to keep a big ground from causing a problem. May be a few amps on the high side. Pops fast it there is a short.
1 - 4 of 4 Posts
