1 - 12 of 12 Posts
I plan on doing the install myself. Does anyone know of a right up with pics? Please send a link if you do know of one. I've checked scoobymods and all over....... haven't found anything.
Thanx
You need a lift, not that it's complicated to do but... you should let a professional handle it to ensure you install the gasket right to ensure it doesn't leak etc. Shops charge about $60-80 for a DP install... why even bother doing it yourself?
Mario
I just did mine. Undo the bolts on the turbo (after heat shield is out), bolts holding it to tranny (I think that's it), bolt on hanger and 2 to cat-back. If you don't have a freak like I did, it should come right out. Putting the new one in is EASY. Just make sure to have a washer or something since the bolts provided are a lot smaller than the holes you fit them in for the cat-back.
RN
Discussion Starter #4
What do you mean by this? Can you explain so I don't make the same mistake?
You need a lift
I have a set of ramps....I think I can get under there with those....I would like to save the money if it's that easy..... how hard can putting on the gasket be?
BTW thanx for the info guys...
I put in a Godspeed downpipe. Lifts, jacks with jack stands or ramps should work for this install.
Mine was a freak because I removed all nuts and bolts and it still wouldn't come out. I had to split the stock downpipe in two to remove it.
RN
Discussion Starter #7
RN,
How did you install the gaskets? Did you use black gasket goowy stuff. Did the stock gasket come off easy or was it caked on?
you should just reuse the gaskets... the stock ones (as long as they dont looked warped or cracked) should be fine.
the stock downpipe likes to hang up on the mounts and can be quite frustrating. If you are not patient, just split it into 2 sections. Getting the one piece DP's on and off after is even more fun ;)
Reuse the gasket between the turbo and the downpipe. It should just stay on the studs, so it shouldn't be a problem. For the gasket at the cat-back, line up the downpipe and cat-back, slip the gasket between them, then bolt it down. Be SURE to have a washer on the cat-back side so the bolt doesn't slip through. If it slips through, it'll tighten on the gasket but will NOT connect the cat-back, so exhaust would then dump under the car. With all the pre-cut holes for bolts, it shouldn't be difficult. Although my install was a real pain, it's very simple in concept.
RN
I now have a more detailed guide up in the "STi Modifications" section.
Anyone having done the install before, please help clarify anything I was unclear about in it.
RN
1 - 12 of 12 Posts
