1 - 20 of 33 Posts
Tools needed, yet not limited to:
Speakers 6 1/2" I used clif designs, Fantastic speakers btw.
screw drivers both types
dremmel with metal cutting wheel
metal coat hanger
pliers
can't remember what else.
First you have to remove the rear door panel
flip out the screw covers and remove the screws
Remove the panel ever so gently by poping out the plastic clips. If one brakes you will need to get some new ones to proplerly put the panel back on.
Remove screws and old crappy speaker!
Remove plastic keepers
Measure up the new speakers, lol.
Discussion Starter · #2 · (Edited)
Ctud
CTUD
Mark out the new hole as close to the bottom corner as you can. Need a marker for this part.
Using a dremmel and some saftey glasses cut out the metal.
Looking at the size difference.
Keep cutting...
Soon you will be done.
using the coat hanger trick you may want to run some new wires... These speakers are 85 watts rms so I will be using an external amp.
You will probably want to remove both seats to make the amp installation and the wire running easier. Tip, take it easy when trying to remove the clips for the airbag, seat belt sensor and what ever else they put under there.
Wiring up the amp was a PITA... Once you found the correct wires to tap into it got easier. Don't ask why the whole dash was taken out.. lol.
So easy a baby could do it!
The sound of the new speakers is fantastic! 10000000x better then the stock junk! More base and way louder! Now I can't hear myself when I am singing to the music.
Most definitetly a must if you like music!
Discussion Starter · #9 ·
trnkmnky said:
and issues with the glass hitting the speakers, or the speakers hitting the door panels??
None what so ever... Probably could have gone bigger. The glass doesn't go down all the way in the back so that isn't an issue. The fronts on the other hand might be a problem.
I also went with 6.5s in the rear
Looks great! Have a question though, how did you mount them? Did you drill a hole and use the thread inserts or did you just use self-tapping screws?
I really want to do this too. When I bought my car it came with Alpine Type-S 4.5" and they are so quiet I thought they didn't work! :lol:
Discussion Starter · #18 ·
I drilled holes and poped the right size screw in. It worked fantasticly.
Discussion Starter · #19 ·
WESTI said:
looks good. i dont think id ever do that though. i could never bring myself to cut metal parts in the sti
Well, I thought the same thing but its in the door so no one will see if you mess up. Just take your time and do a little bit at a time.
The sound difference is phenomenal! :tup:
1 - 20 of 33 Posts
