1 - 14 of 14 Posts
Anyone tell me how to get fog light bulbs out the easiest way?
Discussion Starter · #2 ·
Bummmp. How do i get these suckers out???
It's not as easy as you would think, can someone please chime in..!
usdm, im just trying to change the bulbs not install fogs. its an 06 also.
Discussion Starter · #6 ·
bump for response
For the 04/05 USDM ones, you just pop off the cover, take out the two screws and pop out the light. I don't know how similar it is for the 06's
actually the fog light surround on the 06 is harder to take off than the 05s ... easiest way turn the wheel to the opposite side you r working on remove the fender well liner tabs it should drop down allowing you to have access to the bulbs from the back of the fog lamps its not worth taking out the entire fog light to change the bulb ...there is about 2-3 tabs on the inside of the fender and 1 or 2 to the front underside of the car
Discussion Starter · #12 ·
808SUBsystem said:
i just did mine for some piaa plasma yellows, ok nevermind your not even in here.
Huh?
Hmm, i did all that before i even made this post when i was just experimenting. It seemed kinda hard with the two screws but i guess that's the easiest way. i need try to get them out w/ my angled screwdriver that i have from my mudflap install.
There's no easy way to remove the foglight bulb. I couldn't get access to it and got really frustrated. I ended up removing the entire bumper - it was much easier that way.
The Foglight surround is easy to remove, simply use a flat screwdriver and pry from the underside. Takes 2 seconds.
However, removing the panel doesn't allow you to remove the assembly. It is mounted by two bolts on the inside of the bumper cover.
1 - 14 of 14 Posts
