1 - 3 of 3 Posts
How much do sti pinks lower our stis?
ANYONE that used these springs. what does the car measure from ground to fenderlip at all 4 corners. im going to test these out and compare them to the eibach springs. i just want to know the drop.
right now from ground to fenderlip im at 25 7/8 front and about 25 1/2 rear
tony
Ok, I measured fender to center of wheel before and after install and alignment and only saw a 1/2" drop both sides front and rear. I also measured again about a week later and the numbers remained the same. Unfortunately I can't find the paper I wrote this all down on.
But, measureing right now on the driver side only, the front fender straight to the ground is 26" and the rear is 25". So comparing that to your stock ride height looks like it could have been not even done except I know I've actually dropped some.
I'm actually very pleased with the handling properties though. The sensation of mid corner lift steering change is almost all gone. Also the change from linear to progressive rate has meant stiffer overall but slightly more forgiving on smaller bumps.
1 - 3 of 3 Posts
