1 - 3 of 3 Posts
i probably going to put an aftermarket deck, subaru tweeter, 3way front and 3 way back
i'm cocerned about the wiring, so i hook up the deck, get the 5 1/2s" fronts and back
and tweeter, is there another wire hanging around and i just need to plug it in the tweeter and mount it to the door?
will it be too weird?
coz the deck probably won't be able to pump out enough sound for the front than the back if i went with components without a crossover
most components have a crossover that feeds the tweeter and the main (larger) speaker. so you run the signal from the headunit to the crossover, which splits the signal appropriately for each speaker.
you say you're going with subaru's tweeter, yada, yada. are you sure you're able to get just the subaru speakers and not a stock head unit??
I've seen places where they offer the tweeters seperate.
As for how the tweeters are wired I don't know. I assume there is some sort of primitive cross over in the door. There are the wires for the tweeters and the woofers. I didn't trace the wires to see where they went.
Sorry I'm not much help.
1 - 3 of 3 Posts
