1 - 19 of 19 Posts
I'm still not really understanding fully how replacing OEM rubber bushings with poly works.
I understand that rubber bushings work by twisting the rubber to provide a counterforce to the moment of the suspension components such as rear trailing arm bushings.
But the poly bushings, they have a metal sleeve that rotates inside the 2 poly half pieces, so how does this provide counterforce to the moment?
Sent from my Pixel 3 XL using Tapatalk
Vendor
Generally not well. The sleeve is the pivot. The poly is filling the void. They tend to squeak and bind. Depending on the application there are OE pillow balls or SPL arms, which use pillow balls as well.
Arcflash LLC - Subaru Suspension
Are you saying they don't work well for just street use? Or does one need to be careful when doing poly bushings for track use as well, due to the binding and such?
If you keep them lubed and clean, you’ll never have issues. I’ve had mine installed for 5 years now. I used to clean them every fall and spring when I would autox. They were always really clean with no cracks in the poly. I’ve since slacked on that to a yearly checkup. Still no issues. This includes being Canadian winter driven on heavily salted roads. Keep in mind, I didn’t go with cheap bushings either, Super Pro has been great.
Vendor
It doesn't... or at least not to any great extent. Forces transfer directly whereas the OEM rubber absorbs some of these forces.
So going to harder bushings means more consistent and improved suspension geometry under loading (bushing keep suspension pivot and mount concentric), increased feedback, as well as increased noise transfer to the chassis.
I would recommend starting slow and with the more common bushing upgrades to see how it suits you. It's not uncommon for people to go to far with this and have to reverse their work as they pass the threshold into irritatingly stiff, loud, vibrating, etc...
I believe that in the street performance world (where actual performance hardly matters) there are people replacing various bushings who haven't fully or haven't well addressed the major factors in handling - basic mounts and suspension. If they had, they would would have gotten to that stopping point first!
"No one" wants to ride in my car but me :) and I haven't even addressed the myriad bushings I might.
ADDED: and I've recently had the importance of camber reinforced via experience. Not enough front camber can make a decent STI suspension useless.
Vendor
I'm saying poly bushings work like poo regardless of how often you clean them on the street or the track. If you want proper racing suspension go monoball. Otherwise don't mess with the bushings.
I agree that poly bushings are crap on anything that has to cycle. They work fine for mounts though. I've replaced every bushing and mount in my car. Well almost. The two small rubber bushings that secure the carrier bearing are still original.
All my suspension bushings that actually have to move are Group N. My mounts are a combination of poly and Group N. However both the Group N rubber and poly have nearly the same durometer rating. You want everything to bend at the same rate. I did them all at once too. I feel only replacing some bushings or mounts causes "hot spots". In other words mixing the bushings means the stiffer bushings will do more work. For example if you replace the pitch mount with poly and leave the motor mounts the pitch mount will still twist. However the stiffer bushings will transfer more of that twisting force to the firewall mount. This is because the soft rubber motor mounts have a higher compliance then the stiff poly pitch mount.
With suspension components you want to maintain as much consistency as possible. Changing some bushings will cause the remaining softer OEM bushing to flex more as they have to keep up with the higher force transfer of the stiffer bushings. This can lead to higher amounts of deflection in the suspension when it cycles. It may not cycle smoothly or consistently which could affect at the limit handling. This also pertains to stiff coilovers on an otherwise stock suspension system. Deflection is often the result. The bushings are the foundation of the suspension system. They keep everything in line. If they are overwhelmed it will degrade overall performance.
The real benefit of rubber bushings is not that they add spring rate. It's the fact that the bushing itself actually twists. This helps to make the suspension very smooth and consistent when it cycles. I don't care how often, how much or what kind of grease you use on poly bushings. You can't match that. Basically every time you hear a poly bushing squeak or creak it's binding. It hangs up then lets go. That inconsistency can cause problems at the limit under high forces.
I have a friend with a 2005 STI. He runs in autocross. He was getting terrible wheel hop in the rear. He's broken probably a dozen left rear halfshafts already. He was constantly taking apart the rear suspension and re-greasing the poly bushings. I told him I would install Group N lateral link and rear knuckle bushings and that should help. Afterward the wheel hop was gone. I don't think he's broken an axle since. I've actually broken two myself from wheel hop. I think I figured out the cause. My AST dampers were done. I've also heard recently that these dampers can get piston bind which would have the same affect as a bushing that binds. So proper maintenance of the serviceable components are important too. I went one step further and switched to KW Clubsports.
I'll also add that by sticking with rubber the car has been pretty tolerable on the street. A lot more than I expected. With street tires it's fairly tame. It's so tight though it can get twitchy on irregular road surfaces.
The best way to go for performance of course is full bearing or Heim joints. However that's essentially full race. They require more service and NVH would be very high. They would however keep everything in line with zero deflection. Also they would not in any way alter the spring rates by generating any resistance of their own.
Vendor
Well put SubySal!
I'll add this; I likemonoball suspension because I can do all the tuning where it should happen: shocks, springs and sway bars.
My 525bhp Porsche uses 100% monoball/spherical bearing suspension. The motor/trans mounts are poly. :tup:
Well put SubySal!
Thanks. Agreed on the monoball/ spherical bearings. They are about as solid of a foundation as you could get.
Poly is good for mounts. My motor mounts, pitch mount, diff mount and outrigger mounts are poly. They work well. I also used poly in my shifter linkage. So far so good there and better than the soft rubber bushings that come in the trunnion joint.
I had to use poly on the swaybars though. No other option. I looked into split spherical bearings, but that was a bit cost prohibitive. The front isn't too bad as the grease lasts a while. The rear requires regreasing after every autocross season. At least it's easy to get to.
Rubber dampens forces - ie reshapes them, smoothing out peaks a bit. The overall forces are the same. You engine or suspension creates a force. The geometry of of what holds things "still", say your engine, does not change, so the proportion of what each part holds doe not change significantly. Smoothing out peaks may be important in terms of fatigue.
Stand on a pieces of rubber on a scale. Does the rubber change the force you body applies to the scale? Account for the weight of the rubber, you would see you weigh the same with out without it - because the force does not change just because there is a piece of rubber between the scale and you.
You understand that rubber or poly will either absorb or transmit force to their respective attachment points based on their durometer rating right. In other words the engine for example applies the same amount of force, but depending on the stiffness of the mount actual movement will vary as will the force applied to the chassis side of the mount. This is significant for example because in the case of the GR's which are known to have a weak attachment point on the firewall. Adding any extra force to the pitch mount attachment point may increase the likely hood of a failure in the firewall sheet metal. A stiff pitch mount and stock engine mounts no longer share the load equally. The engine mounts have more compliance. They will let the engine deflect more than a stiffer mount. The poly pitch mount will not comply as much so the same amount of movement will transfer more force over an OEM pitch mount.
You're talking about one point of contact. I'm talking about multiple points of contact in a system. You're talking about a static load and I'm talking about a dynamic load.
anything absorbing the energy in motion is actually transforming that energy into heat. How much heat do bushings create? Rubber is not a great conductor of heat so if energy transformation is occuring they will be hot. Are they?
We agree here
They "share" the loads almost completely according to their geometry. That isn't changing significantly despite movement at one end or both.
Bushings may be modeled as a spring deflecting over time slowing the rise and fall of the force - say on the firewall though a pitch stop. They do not heat up dissipating energy. They dissipate an inconsequential amount, they return almost all of it as they deflect back their original position.
Interestingly force dampening at any point of contact or location has the geometrically proportioned affect on all the other points in the system! [ADDED: Think of a see-saw - put dampening pad under the ends. If unequally weighted, and either end impacts the ground, both ends are slowed by the dampening at the lower end.] So, increasing the durometer of a bushing lessens dampening "felt" everywhere! Yes doing so can cause fatigue.
But if high forces are present (from abuse and/or high torque) there will be much deflection. When during that deflection the full somewhat linear portion of the spring action is used (IE the bushing is crushed), then until the force is lessened it will no longer contribute to further damping. Then a harder bushing would certainly have been appropriate. It will not provide as much dampening over an equal range of force, but it will be contributing at higher forces, and may well have greater overall effect when higher forces are present.
No. I'm talking about physics and its laws are followed for any number of contacts.
I'm discussing both ...
Just checking in on the original question. Rubber bushings do NOT work by twisting the rubber, in fact that is when they are not working right. Bushings are to locate the various components in space and avoid a metal on metal contact (leaving out all metal / ball joints for the moment). Using the example of a sway bar, ideally you lubricate your rubber bushings every so often, and the bar twists inside of the bushing based on the relative movement of the wheels. The rubber should not be rotating with the bar if there is lubrication.
By locating the cross-piece of the bar with the bushing/housing/bolts at each end, you force it to operate strictly as a torsion spring. To do this there are forces up and down at each end. The rubber does deflect under those forces and this movement happens with a lower spring rate than the bar, so that lessens the bar's effective spring rate.
Also, the rubber absorbs vibration, keeping it quieter in the car.
Using poly or other firmer material locates the bar in space with less deflection and increases the effectiveness of the bar. If you increase the force/unit movement of the bar + bushing, it provides more stiffness or resistance against movement, whether you do it with a new bushing or a bigger bar. The curve may be a little different, less linear, with rubber vs poly, but either way it is spring rate of the combination.
But if you don't lubricate the bushing/bar interface, then that introduces stiction and really throws off the curve, as the twist in the bar isn't consistent with rotational position. No matter whether it is rubber or poly. IMO having unlubricated sway bar bushings of any material is a much bigger source of inconsistency than having good rubber ones.
If the car benefits from a stiffer sway bar rate, then fix that. Only change from rubber if that is the best way to fix the problem.
Many control arm bushings do twist by design, and is why you do the final torqueing with the vehicle on the ground. These types of bushings do not have a way to use lubrication. The rubber is literally attached to both the race and the metal bushing and the bolt is torqued for a clamp load on the metal bushing.
Stock bushings, almost all them have only one function and that is to minimize NVH. Metal to metal is otherwise not generally an issue. The engineers would fasten everything together - bolts, weld, whatever works for the application.
Discussion Starter #18
That's 100% correct, and is why I want to change all bushings to spherical rather than poly. I don't like tightening at load and expect rubber bushings to do the work. Spherical can tighten at any position.
Why exactly do you want spherical bushings? Are you drag racing, or doing heavy track days?
If this is a daily driver, or winter driven, the NVH increase of spherical vs poly might not be something you’ll enjoy. Winter is really harsh on spherical setups.
1 - 19 of 19 Posts
