In recent months we have found out that many people rely on the factory balancing of brand new cranks in their engine builds. This was determined by disasembling several dozen built engines over the course of the year and noticing the cranks are untouched and not within a performance spec. or speaking with some of the people that have admitted to doing so.
In a recent production run of our crate engines I decided to put together an analysis of how well or poorly the factory crank is balanced. Without getting too technical on the ISO / SAE Tolerance formulas for balancing a crankshaft, I am going to show what the factory shoots for.
The factory USDM STi crank weight averages 20#'s
I used a 7200RPM rev limit in the formula.
At this weight and RPM the tolerance formula determines the tolerance is 3.8grams per inch.
The crankshaft correction radius is measured at 2.8".
Giving us a 1.3grams of tolerance or better....
In the photos below you will see that the factory tolerance of the four subject crankshafts are within the ISO/SAE tolerance for the factory RPM rev limit for a non-performance built engine.
When a crankshaft is balanced for performance we use a much stricter Tolerance formula that calculates the tolerance to be no greater then .54grams at the stock RPM limit. This formula determines the factory balance of the crank out of spec. for a performance build.
Below you will find photos of the four subject crankshafts better then the .54grams tolerance.
At AR Fab we take this formula to the next level by increasing the RPM limit at which the crank is balanced for from 7200rpm to 9500rpm which puts us to .4grams or better.
To take things a few more levels further.... all AR Fab in-house Complete builds get balanced with the flywheel, timing belt cog and harmonic balancer installed.
(BTW of the dozen or so used factory flywheels we have checked or balanced are lucky to be balanced with 5 grams...)
Below are a few photos of the processes taken to balance a crankshaft.
Even the shop dog, SUBY, gives her paw of approval...
More to follow!!!!
Howard
More to follow!!!!
Howard
