Hose placement
409 Views 4 Replies 3 Participants Last post by  Dextr
So I am new to sti engines. My old motor seized. I had a tech that specialized in foreign cars replacing it. Stuff came up and he left me with it unfinished. I believe I have almost everything back together then I find a random hose under the intake that I can’t seem to place. Also the coolant lines off the throttle body. I can’t seem to figure out how those are run. Any help would be much appreciated.
Automotive tire Motor vehicle Automotive design Hood Automotive lighting
Automotive tire Motor vehicle Automotive design Gas Automotive fuel system
1 - 5 of 5 Posts
If you go here and type in your model theres diagrams
Subaru Parts Online from Subaru of America
Also this from a 2013
2013 subaru sti USDM Sedan / PCV & Intake diagram | IW STi Forum
The one off the throttle body is part of the PCV system
I can only help with one coolant line off the throttle body. In your PIC, if you follow the outside edge of the red silicone hose of the throttle body straight down. You will see an oil galley plug (I don't remember if it's an allen or torx) but it's the circular plug in your pic. To the left of that, is a nipple that should go to one of the coolant lines. In your pic, it's at about the 10 o'clock position from the oil galley plug.
I got the one next to the oil galley plug. There is bother smaller nipples right off the intake manifold. It’s kind of hard to see in the picture. Bottom left nipple in the picture.
ok, that small nip is a vacuum line that connects to the bypass valve.
1 - 5 of 5 Posts
