Honda owner looking to convert
2629 Views 24 Replies 14 Participants Last post by  A1ainSTI
First and foremost, I am a total turbo noob, the 2014 STi will be my first. I have owned Honda’s all my life and I have driven them as I see fit. My daily driver is an auto 96 accord with 219,000 miles on it and never had a failure of any sort with 1 starter as the exception. My toy is a 90 CRX Si that handles beautifully with extensive suspension mods. The CRX I punish it every time I drive it, it sees redline constantly. As I have spent countless hours on here researching, it seems to me that the STi may not be the car for me, and I am not buying a Mitsubishi. It doesn’t sound like a car that can be driven to its limits on a daily basis. Please correct me if I’m wrong. First off I would baby the hell out of this thing for at least 2,000 miles. I babied my 08 Tundra for 1,500 before stomping on it or extensive towing. Now @ 40,000 miles it still purrs and scares the hell out of whomever I am passing. I have a long mountain commute, over an hour each way, mostly crappy weather, and lots of old people or people that are in no hurry whatsoever. There is very limited places that I can pass 2 or more cars with Honda that makes 140hp, and that’s being conservative. Tundra, CRX no problem. The little CRX I don’t drive in the winter, 1,850 lb. car with 8” wide tires not such a great plan on icy mountain roads. And the Tundra, well 4 mpg if you put your foot in it, I would be filling up (premium) every 3 days. No thanks. Yes I grew up in the glory days of Hondas, back when they made good stuff, the early days of the VTEC’s that you just couldn't kill. Honda hasn’t made anything decent since the S2000, which isn’t practical at all. Are there any former Honda guys/gals that could help me change persuade me (more importantly my wife) more. I fell in love with the STi’s since I first saw the 22B. Thanks!
I did find this and read it thoroughly: http://www.iwsti.com/forums/faq-newbie-forum/174091-honda-owner-here-but-fan-iwsti.html
1 - 20 of 25 Posts
The STi is the jack of all trades (master of none) for a daily driver. It plows through any weather with impunity.
Can I blast thru the mountians using all revs, if needed... and still be reliable as a Honda though?
I guess thats what I'm getting at.... all those miles and I turn the key and it fires right up. In order of priority,
Reliability, fun, fast, comfortable.
The car is great, but it is a bit temperamental and you do have to take care of it. If you only throw a good tune on it, it should last a long while , but if you drive aggressively the car may let you down.
To give you an Idea I daily my STi, I have over 55k on the body and 8k on engine # 2. I'm building a built engine for engine #3.
I have done everything I can to eliminate problems, but if I do drive the car hard (which is occasional) then I better be prepared for the consequences. In terms of reliability it is nowhere near a honda.
STI is not as reliable as an NA honda.
i'd say, STI = fun - fast - reliability - comfortable.
But then again, you won't have to hold the revs. Once you do, you'll think twice about doing it :bow:
I live in Knoxville and drive the plateau frequently with my 2011 STI. I haven't owned a Honda but very familar with s2000. They are different cars, STI is a torque monster no need to go beyond 6500rpms (The STI or WRX is more like driving a low reving V8)...just use the torque from 3k up. Hondas rev to make power so they will drive significantly different and also handle a lot differently...need to try one first to see if it suits you.
Reliability...Hondas are very reliable (drive train) and take minimal care. Parts are generally reasonable and easy to work on. STI/WRX are both reliable but tend to be a little more quirky and require more frequent maintenance service...ie, engine oil change, trans/diff changes, tires, etc. Subaru parts are generally reasonable but I'd say a little more expensive than Honda.
Having driven s2000, I'm less satisfied with the power delivery/power compared to the STI. I like the s2000 handling, but most other Hondas are front wheel drive, which I detest.
Hondas and STI/WRX are different beasts, so you need to test drive and determine what you like best. If you've grown up on front wheel drive Hondas you may not like the AWD, torquey, handling charasteristics of a Subie.
Since it is turbocharged, there are a lot more factors you have to account for when modding the car or you'll do irreparable engine damage. I've had my car for 5 years, 80k miles without any problems at all.
Just don't redline it (shift a few hundred RPMS short) and don't slam gears or dump the clutch and you'll be fine. Change and check your oil religiously as well.
Coming from a 95 Accord CD5, than a boosted 95 Prelude BB2, to an '05 STi.
As everyone else has said, they're more quirky/temperamental, require more maintenance, parts are a TINY bit harder to come by, but I don't regret a goddamn thing.
"Comfortable" is basically a joke (at least with the older GD's, newer GR's are more comfy), so I'd agree it goes; fun - fast - reliable.
I still wouldn't put reliable last tho, cuz my GD has 106K miles, stock block/turbo, I beat the PISS outta her, have ran up to 2-2.5qts low, on an off-the-shelf tune. Just replace normal wear and tear items like CV boots, BJ's, tie-rods, etc...
Go drive one, see what you think. :tup:
The 2006-2011 Civic Si wasn't a decent Honda? I had 70k miles on my stage 2 supercharged Si and it never gave me a problem. It was a great car and took everything I threw at it. However, I decided to upgrade to the STI and I haven't looked back. One thing I have learned is that proper maintenance is key with these cars.
I've been driving a Civic EK with a JDM ITR B18C with a Jackson Racing supercharger and LHT AWIC. It is a very fun responsive car. Like you, it is punished every time it is driven. I've had this setup since 2006.
I also own a '11 STI sedan that has a slightly larger turbo, supporting mods, and light suspension work.
They are very different animals, but both fun to drive in their own way. The Honda has proven durability and reliability on and off the track. VTEC and the 8,500 rpm redline sound glorious. I used to be afraid of the car's power until I owned the STI.
The STI looks good, and has the power. You need to anticipate needing the power by keeping the revs high or downshifting to spool up quickly. The acceleration is impressive and not scary because of AWD. The car is heavy and takes a split second to react to commands.
The first few months with the STI, I thought I made the wrong decision because the Honda was more fun to drive. Eventually I learned its characteristic and equally enjoyed driving it.
In bad weather, the STI is the car to drive. The Civic will wheel spin and/or hydroplane where as the STI is absolutely composed.
So in a nutshell:
Both cars are fun to drive in their respective ways.
Honda reliability is not questioned. The Subaru ringland failure is always at the back of my mind.
Safety goes to Subaru for AWD and high tensile B-pillar reinforcement.
Choose your weapon to convince the wife. :)
I did the Honda thing a long time ago (back in '98 with a 91 civic hatch). It was definitely fun, but the STI is a better car. It is far more practical, and handles much better.
Just remember, don't abuse the car i.e. redline shifting, dumping the clutch, etc, and it's plenty reliable, BUT it is a turbo car, and there is a lot more that can go wrong. Forced induction is hard on an engine, period.
Right now, I wouldn't rather have anything else....well, I would like an EVO 10 MR, but not instead of, rather inaddition to. :)
The Sti will be faster and pull stronger but you will sometimes miss the higher redline and the vtec wail of a Honda. I'm a big fan of naturally aspirated low torque high rpm engines so the transition to a sti takes some getting used to, I still forget to upshift sometimes when driving the sti, after driven a car with 9000 rpm redline for 7 years.
I was gonna get a FD2 Type R before settling for an sti, yes you heard me, settling for an sti. Unlike most I don't care much about straight line performance or passing other cars, I'm in it for the joy of nailing a corner perfectly with an underpowered car but the sti doesn't disappoint at all especially with the corner exit punch. Go get the sti.
55 thousand miles and you are on engine #3? Holy crap. Is this a maintenance issue you do you beat the hell out of your cars?
I work @ Y-12, so passing someone coming to work is not an issue, going home is a another story. Engine oil change, trans/diff changes, tires, etc, this I can handle. The guy that posted earlier 50,000 mile an on his 3rd motor, that I can't live with.:eek:
Replacing engines is NOT common, but if they are heavily modded or not correctly then yes you can eat a motor.....and its an expensive replacement. If you stay at stage I or even stage II with the correct tune you shouldn't have problems. Like any boosted engine it will likely not go 200k mi like an asperated inline 4 cyl. Keep it stock or stage I and its very reliable.
To me the STI has plenty of power and torque for driving in our area and the awd is great. I spent most of my money on handling and chassis upgrades. As with all awd cars they tend to push so changing swaybars, stiffening chassis and even upgrading struts pays big dividends in handling and driving enjoyment.
You'll see lots of people talking about 400whp and higher, but that's not my thing. Give me a 300whp car, good handling, lots of controllable torque, and use flexiblity. The dreaded "ringland failure" is overstated on the forums. Does it exist? Yes, but I personally don't know anyone that has had this failure. If you're concerned about it, leave the motor stock and rely on the 5 year warranty.
As you may know, awd drives differently, especially in the corners. Its slow in, fast out to get the most out of the car ....just the opposite of a low hp/tq motor.
No I'm on engine 2. I'm building engine 3.
Oil change at 3k with samples sent to blackstone. Tested between Rotella T6, and Eneos 5w-30. I currently run Rotella T6 with moly additive due to summer time (Will switch to Eneos during winter time).
Full fuid change at 30k. Changed to Amsoil Severe Duty gear oil. Power steering also done at 30k. Dot 4 brake fluid (ATE Super Blue) done at 15k (with SS lines) and at 45k.
Protuned. By reputable person.
I had my fuel pump fail during tuning. That blew the engine.
I'm just saying that these engines are built on old technology.
These cars are not track cars. They cost too much and are expensive to keep in track shape.
For Reliability I've done/ Suggested:
  • Equal length header to remove engine heat more easily
  • AOS to prevent fuel dilution/octane dilution to prevent knock
  • 1 meter fuel line extension to prevent/reduce water hammer causing resonance at certain rpms causing lean conditions
  • Aftermarket radiator for thermal stability
Suggested for track use:
  • Oil temp gauge to determine when engine is too hot
  • Increased capacity oil pan Thermal stability and allow oiling while in turns
  • Oil cooler engine cooling
So before you think that I just beat the crap out of my car think again. Most times I'm just in S mode.
STIs can be reliable cars if you take care of them properly and don't go crazy modding them. Most of the reliability issues can be traced back to mods. Personally I have 106xxx miles on my STI and I drive it hard, Auto-X and so on, with no problems. The engine/drivetrain is basically stock and I keep up with maintenance and use good oil.
Some people have had unfortunate issues (like mister 3rd engine above), but those are the exception. But if you are buying new, you will have a warranty, so there's not much to worry about there.
Every Wednesday nite the KSOC (Knoxville Subaru Owners Club) meets at the Sonic on Kingston Pike/Walker Springs Rd at 7:30pm. Why not stop by and speak with local Subie owners.
I can not imagine a better car to drive thru the mountains with. I did it regularly with my 08 STi for snowboarding and plan to do the same with my new WRX.
It seems you can't stay wide open on a mountain road like you ever could on the track. So even though your CRX would prove to be more reliable for track abuse including extended WOT... the STi proved to be extremely reliable for myself and many others as a car you can drive really hard on the street.
1 - 20 of 25 Posts
