1 - 11 of 11 Posts
so i recently found out that you can add a gallon of toulene/toluene mixed marvel mystery oil and get a good octane boost. is it bs or does it work and how often can i use it. i love my car and in cali were suck with crappy 91 octane and those $12 dollar octane boosters work but too expensive. any recommendations of the use of toulene or should i use something else?
It works, but it doesn't have a dramatic effect on octane, and toluene/xylene are usually around $10/gal. There are other much more cost effective "traditional" ways of increasing octane - methanol injection, race gas, and torco being the top 3.
I can get 110oct and 112oct locally at the pump for $6.25/$6.95 per gal. For a while I was adding 3 gallons of 110 to every fillup of 93... it added $10 to the cost of a full tank of gas and brought the octane level up to 96+
Discussion Starter · #4 ·
spazegun2213 said:
Dude, if you are really that serious about giving your car the correct gas (which is 91 IIRC) just buy race gas.... a 50 gal drum is cheap.
where do you get it? the 50 gal drum?
the the toulene has been discussed before on the boards,
im with others saying, just go with the race gas
Discussion Starter · #6 ·
uuhhh..... i live in california and havn't heard of pumping 110 cuz the best we got is 91 so pumping 93 or 110 can't happen unless i buy leaded gas which isn't too could emission control systems.
I live in Cali too and I can get sunoco 104 unleaded from a local vendor. Just look around for a place.
At the worst case, I used to get VP110 for my shifter kart at a local motorcycle shop. It came in 5 gallon drums. They sold VP98 which was unleaded; I'm sure you could fine someone selling Sunoco 104. $32 for 5 gallons, but this was two years ago.
The bonus is that you don't have a fifty-five gallon drum sitting around in your garage. Race gas smells. =P
There was definitly just a discussion on this whole thing, check some recent threads ;)
Add 3 gallons of Toluene and a few ounces of MMO to at least a half tank of your normal 91.
Reset the ECU, go romp on it, and see if it feels different.
I have a feeling it will because you're used to 91 octane, and you'll end up being hooked on how your car runs on the higher octane :lol:
3 gallons of Toluene to a half tank of 91 is probably around 96-98 octane... I forgot the exact formula to figure it out, but it'll be much higher octane than your car is used to ;)
Here's the catch..
I don't know about where you live, but around here pretty much every place has banned Toluene and the only place I can consistantly get it is Sherwin Williams. It's normally $19.99 per gallon. That can add up real quick. Luckily, with a business discount, I can get 3 gallons for a little over 30 bucks.
In my last job, I had access to all the toluene you could ever want. 10,000 liters every few days. Ahhh, the joys of pharmaceutical manufacturing. :)
1 - 11 of 11 Posts
