1 - 15 of 15 Posts
just a quick warning... I can't tell for sure what kind of hose you are using from the picture, but things will get QUITE HOT (read: melting-plastic-hot) at the connection point you have made to the dust shield. Be sure to use a hose that is rated as such.
i think it's a good do it your self job. the duct looks like it will work just fine. i agree on the melting. as for the center getting the blow. well it appears that it will work. think of it this way. he is attempting to do something cool (no pun intended). and its going to do a lot better than the stuff he had on there before... nothing!!! good luck.
Discussion Starter · #12 ·
All right a slight update. just wanted to let you know after my first track day the left tube did not hold up. the right one is fine. later this week i will be looking for new materials i will keep you uopdated
1 - 15 of 15 Posts
