1 - 20 of 20 Posts
I tried doing a search about this topic but I was not successful in what I was looking for.
Recently, I have come to the decision of getting the car tuned with the EcuTek program. However, the thought of going with a catless D/P has been crossing my mind as well.
When I purchased my car a month ago, the car already had an HKS D/P. I had it removed and replaced with a full stock exhaust system for fears of buying a car and have the warranty shot.
I currently have the stock D/P with the SPT cat-back exhaust. I have heard of going with Invidia for the D/P. My friend has the Invidia D/P on his STi and swears by it.
My question here is what are your thoughts about the HKS d/p. Should I use that one or sell it and get a different one?
What are the benefits/downfall of a divorced W/G flange on the D/P?
Please give me some feedback on this topic as I continue to learn this platform. This way I can make a better decision if I'm keeping the HKS or get rid of it.
Thank you for your time.
Ive had the hks dp on my car since it had 8k on the odom. At the time, there werent many choices. XXTuning recommended it. I bought it with their first set of gt spec II headers. Initially, I suffered from boost creep, which they fixed easily by porting my turbo. The hks has been a good dp. I am changing to a Cobb, because my new exhaust (Tanabe) has a slide flange on it and it wont mate to the HKS without leaking. But overall, a good product.
There will be more turbulence with the HKS DP because it doesn't have the bellmouth design. Im assuming it would hinder your performance a little versus a bellmouth design because its not a clean flow.
HKS DP is a very good downpipe. Very nice piece of pipe. Proof to me that bellmouth is better than the flat flange...on the turbo the HKS is more than enough. Plus is a an awesome pipe to go with EWG setup :naughty:
i had all styles of DPs and never noticed any difference in power
I dont really know much about the hks since im new here, but when I was researching what downpipe to buy all I heard were negative things about it. I read that because of the divorced design the temperatures of the two tubes are different which makes it prone to cracking. I ended up going with a helix catted downpipe and catback and I couldnt be happier.
Poor design. That's the reason it's cheap, and unused from word of mouth. It is essentially the same design as the stocker, as it has a plate that blocks the wastegate. The only benefit over the stock pipe, is that it is catless. But that is not much to say, when the stock one is a poor design as well.
+! for invidia dp
In my experience, the invidia V2 and the TurboXS have been the nicest downpipes, depending on your individual setup. Stock turbo-Invidia V2. FPGreen or similar- TurboXS (4.5 inches will come in handy at 6K rpms)
Or you can make a crazy IWG/EWG setup using a cut bosal DP! All the sound of an EWG, none of the cost!!! :devil: ok fine don't do that, but wouldn't it be fun?
1 - 20 of 20 Posts
