1 - 5 of 5 Posts
Hello,
What would cause for AF Learning 1 to reach -13 when letting go of the gas pedal after accelerating while still being in gear. In every other situation the car performs as intended. Any help would be greatly appreciated.
Thanks
One of your learning ranges has learned a -13 percent correction. Probably the B range.. Set your monitors to AF Learning A, B, C and D to see what one it is.
Vendor
What mods do you have and what map are you running?
Hello,
Thanks
1 - 5 of 5 Posts
