1 - 1 of 1 Posts
Hey fellas, from the Caribbean, have an 03 Singapore Wrx, same spec as a euro Wrx, need some help, I have an ej205 motor but I spun a bearing, my mechanic at the swapped my motor with an engine from a gtb legacy around 2 years ago, car has been down lately and trying to start it, I'm unsure if the edm Wrx used the same timing triggers as the JDM models or the üsdm models, is the edm motors with no avcs phase 1 or phase 2. My car is ver. 8 non avcs, car currently not starting, misfire on all 4 cylinders, unsure if the mechanic swapped the timing gears over, car started but never made boost. Getting fuel, getting compression, getting spark, currently have the timing trigger with multiple teeth on the crank sprocket and 2 notches on the cam sprocket but it seems these are the wrong gears, is my ecu built to read phase 1 or phase 2 crank and cam gears ?
1 - 1 of 1 Posts
