1 - 3 of 3 Posts
hey guys im trying to isntall my fuel pressure guage for my car and i need help to where i shoudl put the sending unit anyone do it before??? :x
thanks
Amir
Discussion Starter #2
ok well i think i figured it out! but my next question is if anyone install the electric water temp guage??? and if so where did you tap into for the sensor? or did you guys just use the stock signal wire as your source instead of installing the aftermarket sensror???
also if you guys know which is the fuel supply underneath the hood? becasue theres 3 lines, and i know one is a return and the other two have to be a supply....., is it the thick fuel lines that are the supply then??? becasue i need to tap into one of them!
1 - 3 of 3 Posts
