1 - 19 of 19 Posts
VSGTS14 said:
yea just use the bov hose, it's the easiest.
ok got it all hooked up, but there is still one thing that is bothering me.
the defi boost gauge will only light up if i have my car lights on, if i dont, it stays dimmed. it wont light up until i turn the car lights on. is this normal?? if it is i dont understand why they would have it set up that way.
thanks,
-Taylor
I guarantee that the power wire that your defi's are getting power from isn't the right one. Use another wire that has power that is related to the ignition. so that when you turn your acc then they light up.
· Premium Member
thanks,
-Taylor
Silly question but did you up the brighteness setting for when your lights are off? The Defi control unit has 5-brightness steps for lights-on and lights-off. Check that. Just press the arrow buttons...
Discussion Starter · #12 ·
· Premium Member
What was the problem, for reference?
Discussion Starter · #17 ·
it was stupid mistake on my part.
on the control unit, i had the meter output cord in the meter output 1 port, i was just fouling around with it and stuck it into the meter output 2 port and it works! i dont understand why it wouldnt work in the 1st one, but w/e
-Taylor
-Taylor
If I remember correctly, meter 1 is for non-BF gauges. Meter 2 is for BF gauges only.
1 - 19 of 19 Posts
