1) Got new front rotors but they arrived slightly damaged, thanks to UPS and poor packaging. Is this something to worry about and would you keep or return them?
2) Hawk Ceramic Pads (Fronts)
The cutout is for electronic brake sensors which we do not have and as you can see, they do not come with brake shims. Do you just run without wear indicator and without shims as well or should I buy aftermarket brake shims to prevent noisy brakes?
You help is greatly appreciated.
