1 - 5 of 5 Posts
Hello! my car is only 3000km....is my first AWD car....so when I heard a noise or a vibration I dont know if is normal or not...:confused:
When I`m in 5 or 6 gear and suddenly I push full gas floor I fell like a vibration from the transmition for a few second and then dessapears.......maybe is normal...I dont know!:confused:
Thanks guys for your help!!!:tup:
Do you have the short throw shifter? I had this problem too, but it went away.
What engine speed are you at when this happens? If it's at low speed (example 2k rpm) it might just be because you're lugging it. It goes away after a few seconds because the engine speed has gone up because you are at WOT. Hope that helps.
Short answer: It's probably normal, but if it gets any worse be sure to tell your dealer. Even if they can't fix it, if it becomes a problem later and you already told them about it they'll have a report of it so they can help you. :)
1 - 5 of 5 Posts
