1 - 8 of 8 Posts
I really need help i have an 06 wrx with an acessport and the street tuner sofware but i cant seem to put out more than 14 psi. Does any one know why?
umm.... whats target boost supposed to be? i'm going to venture a guess, it's really hot outside by you?
my target is 19psi and i have a helix down pipe and the blitz nur spec-R exhaust.. no its not hot out side its about 72 F
What WGDC's are you running? Did you know that there is a relationship between the low and high WGDC settings? I had to set my lows within say 5 to 10 of the high to hit the "high" values (90 on the high, 86 on the low for example).
What values are you running?
WolfPlayer said:
The WRX doesn't have high and low tables. They just have a max WGDC table.
19psi on a stage 2 WRX? You're brave. I don't see running much past 17.5psi on those cars with a TBE.
t
That would be ok on the 2.0l WRX, but on the 2.5l I can't see the 13T holding 19psi for more than a couple hundred RPM down low in the RPM band if that.
TMS
1 - 8 of 8 Posts
