1 - 20 of 51 Posts
Welcome to the Gvfs 2008 OBP GRB Member Journal.
The 8LV was purchased during the 2008 EOY incentive program.
*Indicates pictures are included in the post
--------------------------Journal--------------------------
  1. Sport Grille 12/06/2008
  2. Blizzaks on second set of 5-spokes added 12/21/2008
  3. Rubber mats and rear tray added 01/31/2009
  4. OEM fogs installed 02/14/2009
  5. Whiteline 24mm FSB (BSF39XZ), 22mm RSB (BSR49XZ), and D-bracket braces (KBR15) installed; procedure written. 05/25/2009
  6. Post #2 - Höen 55W Endurance bulbs installed in fog lamps 06/14/2009 *
  7. Post #5, Post #7 - LightWerkz Angel Eyes installed 6/26/2009 *
  8. Post #6 - Hella Supertones installed 7/3/2009 *
  9. Post #8 - JDM start button and surround (83031AG001, 83002FG060JM) 7/4/2009 *
  10. Post #9 - Vinyl fog light overlays 7/4/2009 *
  11. Post #13 - Cobb Stage I installed 7/25/2009
  12. Post #16 - Whiteline rear diff bushing inserts installed 8/9/2009
  13. Post #18 - JDM Subaru oil temp and boost kit installed 9/18/2009 *
  14. Post #25 - Fog light rewire completed 10/7/2009 *
  15. Post #28 - Whiteline rear subframe bushing inserts (W0598) installed 10/08/2009
  16. Post #28 - Group N transmission mount (ST410224S000/D1010FE000) installed 10/09/2009
  17. Post #28 - Group N engine mounts (left D1010FE120, right D1010FE110) installed 10/10/2009
  18. Post #29 - Damd flat-bottom steering wheel with red stitching installed 10/25/2009
  19. Post #33 - Harman Motive turboback exhaust and Cobb Stage 2 installed 5/9/2010
  20. Post #34 - Rear fenders rolled and pulled 6/29/2010
  21. Post #35 - 18"x9.5" +45 Enkei PF01s with 275/35 Falken 452s installed 7/15/2010
  22. Post #36 - Lamin-X tail light overlays 7/16/2011
  23. Post #37 - Whiteline steering rack bushings (KSR206/KSR207) installed 9/4/2011
  24. Post #38 - AEM intake installed 9/13/2011
  25. Post #39 - Whiteline 22mm RSB (BSR49XZ) removed; 24mm (BSR49XXZ) installed 10/02/2011 *
  26. Post #43 - Re-usable carbon filter mod 11/26/2011 *
  27. Post #48 - Whiteline KDT905 installed 5/27/2012 *
  28. Post #50 - Partially debadged hatch 8/19/2012 *
  29. Post #51 - Whiteline front lower control arm bushings installed 11/25/2016 *
--------------Current Modification List--------------
Interior:
JDM start button and surround (83031AG001, 83002FG060JM) - Post #8 *
JDM oil temp and boost gauge - Post #18 *
Damd flat-bottom steering wheel with red stitching - Post #29
Re-usable carbon filter mod - Post #43 *
Exterior:
Sport Grille
OEM fog lights with Höen 55W Endurance bulbs - Post #2 *
LightWerkz Angel Eyes - Post #5, Post #7 *
Hella Supertones - Post #6 *
Vinyl fog light overlays - Post #9 *
Fog light rewire - Post #25 *
Rear fenders rolled and pulled - Post #34 *
Lamin-X tail light overlays - Post #36 *
Partially debadged hatch - Post #50 *
Engine/Engine Bay, Tune, and Transmission:
Cobb Stage 1 - Post #13
Group N engine mounts (left D1010FE120, right D1010FE110) - Post #28
Group N transmission mount (ST410224S000/D1010FE000) - Post #28
Harman Motive turboback exhaust and Cobb Stage 2 - Post #33
AEM intake - Post #38
Driveline:
Whiteline rear differential bushing insert kit (KCA398/KDT903) - Post #16
Whiteline rear differential forward mount bushing kit (KDT905) - Post #48
Suspension:
Whiteline 24mm front anti-sway bar (BSF39XZ)
Whiteline 24mm rear anti-sway bar (BSR49XXZ) - Post #39 *
Whiteline rear anti-sway bar mount braces (KBR15)
Whiteline rear subframe bushing inserts (W0598) - Post #28
Whiteline front lower control arm bushings - Post #51
Steering:
Whiteline steering rack bushings (KSR206/KSR207) - Post #37
Brakes:
All stock
Wheels/Tires:
-Summer: 18"x9.5" +45 Enkei PF01s with 275/35 Falken 452s - Post #35 *
-Winter: Stock 5-spokes with Blizzaks
------------------------To-Do List------------------------
  • AM wheels and tires
  • Fender roll and/or pull
  • Anti-sway bars
  • Powerflex adjustable rear upper control arm bushings PFR69-510G, PFR69-511G (product)
  • IC rock guard
  • Springs/coilovers
  • Boost gauge
  • Oil temp gauge
  • AccessPort Stage 1
  • Rear subframe bushings (procedure thread)
  • Rear diff bushings (product, procedure thread)
  • Trailing arm bushings (W0568) or whole arms (KTA125)
  • Front control arm bushings (product)
  • Group N tranny mount (product)
  • Group N engine mounts (product)
  • Steering rack bushings (instructions)
  • ALK (product); Might use PowerFlex PFF69-502G instead of WL.
  • Rear camber adjustment bushings
  • Seats (USDM seat mod thread)
  • Downpipe/TBE and Stage 2 map
  • Custom tune or protune
  • DAMD flat-bottom wheel (wheel removal how-to) (thread)
  • SATNAV with bluetooth; digital gauge device for display or carputer for tuning
  • Stainless steel brake lines
  • Angel Eyes (how-to)
  • Hella Superones (how-to, diagram)
  • Intake silencer delete (thread) This is a bad idea; not going to do it.
  • AEM intake
  • JDM Subaru oil temp and boost gauge kit
  • OEM fog light kit H4510FG030 (instructions)
  • Fog light rewire
  • Lamin-X tail light overlays
  • Setting Saver (instructions).
  • Partially debadge hatch
Discussion Starter #6 (Edited)
Supertones
http://i670.photobucket.com/albums/vv68/gvfs_rocketmail/STI/supertones_both1.jpg
http://i670.photobucket.com/albums/vv68/gvfs_rocketmail/STI/supertones_left1.jpg
http://i670.photobucket.com/albums/vv68/gvfs_rocketmail/STI/angel_eyes_supertones_both1.jpg
Supertones were later painted black.
Discussion Starter #7
LightWerkz power converters
Here are some bad pics of the power inverters affixed via double-sided foam tape to the frame rails just behind the headlights. All three pics are of the left inverter. On both sides the light harness (from the parking lights) was extended to behind the headlights. Plugs connect the inverters to the harnesses.
http://i670.photobucket.com/albums/vv68/gvfs_rocketmail/STI/angel_eyes_pwr_inverter1.jpg
http://i670.photobucket.com/albums/vv68/gvfs_rocketmail/STI/angel_eyes_pwr_inverter2.jpg
http://i670.photobucket.com/albums/vv68/gvfs_rocketmail/STI/angel_eyes_pwr_inverter3.jpg
Discussion Starter #8
Re: Gvfs 2008 OBP GRB
Pointless JDM bling.
http://i670.photobucket.com/albums/vv68/gvfs_rocketmail/STI/jdm_start_button3.jpg
http://i670.photobucket.com/albums/vv68/gvfs_rocketmail/STI/jdm_start_button2.jpg
http://i670.photobucket.com/albums/vv68/gvfs_rocketmail/STI/jdm_start_button4.jpg
Discussion Starter #9
Discussion Starter #11
Re: Gvfs' 2008 OBP GRB
does that JDM start up button actually work?
Not a chance. Nor would I even consider spending the ridiculous amount of money it would cost for an OEM conversion. I would like to re-purpose the switch for something like additional lights.
Discussion Starter #15
where there is will, there is a way~ you're one step closer to push start than most of us~ i think it can be done... just dunno how... :rolleyes:
It can be done by throwing money at it--bunch of sensors, harness changes, new keys, new lock cylinder, new ECU. The problem is a lack of will to spend money on it. Coilovers, wheels and tires, downpipe and custom tune, boost gauge, and bushings/mounts will definitely take priority.
Discussion Starter #16 (Edited)
Installed Whiteline rear differential bushing kit KCA398. Took me about 1.5 hours just to work off the forward member nuts. The rest of the job was very simple.
I suspect that this is the simplest of the bushing/insert upgrades that can be done on the car. I still have rear subframe and steering rack bushing kits to install.
Discussion Starter #17
Hmm. Whiteline has this listed as KTD903.
1 - 20 of 51 Posts
