21 - 40 of 56 Posts
Discussion Starter #29 (Edited)
GTspec Fender Braces
Installed fender braces yesterday then repainted the bolts to make sure they don't rust. They defiantly made a big improvement. It feels like there's less body roll. More controlled. I guess that's why they reinforced this area on the 2015's.
5/11/14​
Discussion Starter #32
Cleaned Up Power
I finally got around to cleaning up the power for the radar detector and my gauges. I was tapping one of the unused fuses previously:
I needed to pull the fuse box out anyway, so I thought It would be a good time to clean up the wiring. I used my multimeter to trace one of the empty fuse slots to a pin on the back of the fuse block:
I dug around through my pile of connectors and found an old radio harness that had the same size pins. I managed to remove one and it fit perfectly into the empty spot in the stock connector (purple wire) and I put a removable connector on the other side:
So now I just put a fuse in the vacant slot for a stock look:
Discussion Starter #34
New Suspension Installed!
Why didn't the car come this way? Lol
Whiteline Com C Front Strut Mounts
RCE Black Springs ( 0" drop, stock struts)
RCE 25.5mm Hollow Front & Rear Sway Bars
Rallitek RTEK-113703 - Front End links
Super Pro SPF3915K - Rear end links
Super Pro SPF2889K - Steering Rack Bushings
GTSPEC GTS-SUS-1404 - Rear Low Arm Tie Rod Brace
Cusco 687 492 RS - Power Brace Rear Member Side
Cusco 692 492 RM - Power Brace Rear Subframe
Cusco 692 477 A - Front Lower Arm Bar Type II
Cusco 692 026 A - Steering Rack Bracket
6/8/15
18000 Miles​
Re: New Suspension Installed!
How do you like the ride with the RCE black springs and stock struts?
6/8/15
18000 Miles​
21 - 40 of 56 Posts
