Hi everyone!!!
I have an 05 wrx and it makes some sort of grinding sound coming from the front end...
This sounds like two pieces of metal rubbing each other and happens in all gears...
Doe not crunch when selecting gears and doesnt seem to have any power loss...
Car is almost stock with only muffler, 19 inch wheels and possible aftermarket clutch...
Noise happens;
•when coasting in gear and I apply accelerator (even if I just touch it faintly)
•when coasting in neutral
•when coasting in gear with clutch engaged
Noise doesn't happen;
•on idle and I do the above
•when coasting in gear (with foot off all pedals)
Car has had oil and filter changed, gearbox oil changed with no chunks of metal on magnet...
Has anyone had the exact same symptoms???
