Greetings from the uk, with a 10 second car
961 Views 7 Replies 4 Participants Last post by  Blackpoolrock
Hi all and greetings from the UK
Just trying to find some forums based in You country to try and see what you guys running big power are doing, picking up some tips along the way I hope.
I'm currently in a type r with the following spec
EJ22T block
EJ257 79mm nitrided crank
Wiseco stroker pistons
Crower stroker rods
ACL main and big end bearings
Cosworth 12mm high flow oil pump
14mm head stud conversion
avcs heads ported and knife edge polished
1mm oversize Cosworth Inlet and Exhaust valves
supertech titanium retainers
supertech double valve springs
supertech valve seats
272 inlet and exhaust cams
Adjustable exhaust cam pulleys
Kevlar timing belt
cosworth billet timing belt guide
Cosworth high flow inlet manifold
bespoke top feed fuel rails
Injector dynamics 2000cc Injectors
Aeromotive A1000 fuel pump
fuelab -10 fuel filter
SM swirl pot
walbro 255lph lift pump
braided clutch line
Exedy hyper twin plate clutch
RCM 100mm trumpet
RCM 260mm Induction cone
Inner wing induction box with 76mm feed to foglight
Beatrush gearbox stabiliser
STi engine mounts
GT spec headers with DEI titanium heatwrap
3.5" rotated down pipe
44mm tial external wastegate
Roger clark return to sump catch can
Braided teflon fuel hoses
Scoobyclinic Garrett Billet GT35R version 2
Custom header tank
STi 1.3bar header tank cap
Hawkeye UK long ratio DCCD 6 speed gearbox
R180 3.54 plated diff
Bespoke braided engine loom
Roger clark lightened pulleys
DEI Titanium turbo blanket
Omni power 4bar map sensor
Odyssey PC680 battery
Fuel lab 3 port fuel pressure regulator
Power steering reservior relocation kit
twin scroll baffled sump
Syvecs S6 PNP ecu with 8 maps, Anti lag, Launch control
STi quickshift
ASH silicone hoses
Summit racing radiator flow panel
3.5" veilside titanium exhaust
wideband lambda fuelling control
NGK Racing 8 spark plugs
New age coil pack conversion
Reverse mounted radiator fans
Turbosmart 3 port boost solenoid
NGK racing 8 spark plugs
Fuelab 3 port Fuel pressure regulator
Millers CRX 75w140NT gear oil
Aeroquip power steering hoses
Wizards of nos nitrous kit
Hyperflow monster intercooler
Wizards of nos bottle heater
Suspension
Custom spec Bilstein B16 dampers
Whiteline 24mm adjustable rear anti roll bar
Whiteline 24mm adjustable front anti roll bar
whiteline alloy rear drop links
Whiteline adjustable front drop links
whiteline front roll centre adjustment kit
whiteline heavy duty steering rack mounts
whiteline anti lift kit
whiteline subframe lock kit
Group N STi rear top mounts
front strut brace
Beatrush rear diff brace
2 1/4 ratio steering rack
Whiteline KTA108 adjustable arms
Cusco rear carbon v brace
Whiteline H brace
Whiteline Front Heavy duty gearbox mnts-RACE (W0584M)
Kartboy Shifter Bushings
Kartboy Rear Shifter Bushing
Beatrush Propeller Shaft Mount Collar
Hardrace Gearbox mount
Whiteline W91379 Rear Diff - support outrigger bushing
Whiteline Diff.mounts in cradle Rear W91380
STi trailing arms
Whiteline KLL124
whiteline W51709
whiteline W61383
Whiteline KCA414
whiteline KBR21-24
Front uprated fender braces
New age front arms for added castor
whiteline max c kca 251m front top mounts
Summit racing front strut brace
Interior
DC2 Red Recaro seats
Black flocked dash
Red flocked centre console
Red flocked zero sports gauge pod
Apexi el2 boost gauge
Apexi el2 oil temp gauge
Apexi el2 oil pressure gauge
Apexi el2 water temp gauge
Personal steering wheel with Black alcantara and red stitching
STi pedals
Metal STi door sills
8 way rotary dial for map selection
STi 6 speed gearknob
Composite firewall
forrester sti digital climate control unit
Dash mounted illuminated horn button
Exterior
STi type ra roof vent
STi version 6 splitter
STi 5 high level spoiler
black crystal headlights
Bi xenon projector conversion
black crystal sidelights
Smoked front and side indicators
STi rear lights
carbon side mirrors
Aero catches
Induction fog cover with air feed
TRS tow strap
Flat bonnet vent
22B bonnet vents
Car is pushing 666.7 bhp at the min with no NOS
Here are a couple of vids of 10sec runs up the strip
http://m.youtube.com/watch?v=j-k15v8SyTU&feature=c4-feed-u
http://m.youtube.com/watch?feature=c4-feed-u&v=9-V_ioEAiS8
Please also look at some of the other Subaru vids on my Chanel !
1 - 8 of 8 Posts
Welcome and that's awesome! I'm not pushing any big power like that
Welcome. I'm just disappointed with that lady in the second vid that's not paying attention to that awesomeness! Women, they just don't get it.
Ok I'm now asking a favour !
If any of you guys dance sharing my vids through any form of media, Facebook, other forums etc be very appreciative, I'm trying to get as many views as possible by this time next week in order to gain some sponsorship to enter europiean time attack next season !
1 - 8 of 8 Posts
