21 - 40 of 101 Posts
Get a DP with a 300 cell gesi, grab a 400 cell gesi and have it welded in upstream behind the turbo. No CEL with the dual gesi set up. I personally opted for the 4.5” body for both, which are rated for 850 HP and shouldn’t be a restriction. I did all of this with a 08+ GR first gen Cobb DP.
owns 2019 Subaru WRX STI Base FP Green Flex Fuel
Reactions: yamahaSHO
Just an update
I added Perrin ELH headers (wrapped) and an EBC and got a new ProTune (gained 10hp, 22tq) but do pop a P0420 now, about every ~70 miles.
Going to try a spacer
The idea of adding the gesi 400 upstream sounds appealing. I’ve been using spacers on my 19’ STi for about a year. Typically, it goes ~1500-2000k before popping cell so it’s livable for me. I’ve got it honed in to the point where it really only pops during long highway cruising once the O2 is in a ready state.
I’ve been running my duel gesi DP for about 10,000 miles and no issues at all. Day to day type driving along with two 5 hour interstate trips. Pretty sure at this point, mine is a non issue. My car is a 2019 as well.
Thanks for the good insight. Do you think your dual set up would hold without popping cell on a higher horsepower build? I mean with an upgraded turbo, bigger fuel injectors, pump, and on e85 the A/F coming out would be significantly richer than stock.
A buddy of mine is running my same set up with a BB5500 and ID 1300’s running about 23 psi on pump. No issues with his.
Again, I bought the 850hp rated converters so that they can handle my eventual 400+ whp turbo set up. I have very little doubt that I will have any problems. I feel great about my set up
Just an update
Ask your tuner to zero out the AFL3 table on your tune.
You need to do that anyways to run a spacer but I had mine done and didn't need to install the spacer because the code never came back.
This table is what causes the car to realize the cat isn't to spec during scaling and throws the infrequent p0420
I've seen one person also using just a single 400 cell with no issues as well. Take that with a grain of salt, y'all, since each car is different.
I have my single cell on my DP set up, just waiting on FPR and injectors and then I'm good to go.
Yeah, I thought about running a single 400, BUT I have read of more than a few 19+ cars still giving the code. So I went my route, because I only wanted to have to cut and weld the DP once. Glad I did and that is one less worry going forward.
I hadn't heard of that one, only that the 300 cells weren't cutting it and the 400s were in the clear, but good to know.
I tell people, get a catless bellmouth pipe, weld a 400 in behind the turbo. If it works, great, if not, add the 300 in the rear before the sensor and you will be golden! And that’s mainly for the 19+ guys. The Cobb pipe with the 300 cell seems to work on all of the 08-18 cars.
I spoke with my local tuner after I told him I was thinking of getting a DP for my 2021, he said not to because of the CEL hassles noted above...
What is the improvement in flow of a double catted DP vs the stock unit?
with the setup he mentioned, quite a bit of power that's added over a stock setup. if you tried it, and decided to go back, just keep your dp and you likely wouldnt have an issue selling a double catted dp provided you have nice set of cats in there
owns 2006 Subaru STi
The biggest benefit is the 3” piping along with the bellmouth at the turbo. The cats that I selected are rated to 850 hp, so they flow plenty and running two pretty much eliminates any chance of CEL issues.
My OBDII status finally went from 3 never being ready (Cat, o2 and Evap) to all 3 in ready status now, took alot of trial and error but finally found the right size for the o2 spacer, 9/16, went from 1/4 all the way to 17/32, which had given a pending P0137 code that never changed to a CEL, even after ~300 miles
Has anyone had 100% long term success with these spacers. Most seem to be a handful of miles bandaide. Sure, clearing a code every 2000 miles isn’t a huge deal I don’t guess, but definitely not the fix that I was looking for….
Looks like the originator has had success for a few thousand miles, as well as a few others too, with varying results.
I think that if you're only going to do FBO besides ELH, then this should be fine. Anything after that has me worried about long term and would warrant a dual GESI setup.
Yeah man, my biggest worry with a bandaide fix, was that my wife loves to drive my car, and I didn’t want to risk it flaking out or going into limp mode with her one day when I wasn’t around. So doing the research and spending the money was well worth it for that peace of mind for me.
Mine was a 2020, Cobb DP w/Gesi, Grimmspeed intake, 1050x with an AEM 340, Cobb FPR, EBC and catback.
Same Protune, just added the spacer with the opening at 9/16
Was getting P0420 without the spacer, spacer with 17/32 and any size under hole was giving me a pending P0137 code, but it never went to a CEL/Perm code, even after several hundred miles, but that prevented OBDII from being ready, which prevents me from renewing my registration in Oct.
With the 9/16 hole, the sensors now went to ready status, I plan to 'burn it in' for a few days and confirm OBDII status, if alls still good, drive down to my auto shop and get the emissions test done
My spacer was from big daddies garage
