1 - 3 of 3 Posts
How do the stock tires handle the cold?
The General German Automobile Association not only tested winter tires just last month, they tested them in the STi size of 225/45 R 17 V. Note that lower scores are better. Basically, it looks like all of the tires are pretty close in performance. Unfortunately, the French tire appears to be the best choice. Rats. :x
Here's the computerized translation:
The report on high-speed (to 240 km/h) tires in the 225/45 R 17 V size is less pleasing. Not that their performance both on snow and ice is generally bad. But nearly everything was problematic due to its width and the low cross section design: On wet roads a water wedge, the wheel forms already swims up and the vehicle becomes so uncontrollable at quite moderate speeds under the tire. Our judgement for the Testkandidtaten could not read therefore differently: less recommendable, thus with the restriction of the increased aquaplaning danger. If you must drive this tire size according to registration certificate in the winter, you should reduce your speed then on wet roads at least. If narrower alternatives (e.g. a 20ër-Breite) are permitted, these would be the first choice. Because you know: In the German traffic filled discharge zones are unfortunately goods in short supply with gravel.
Dunlop FR winter sports M 3
Rating: * / Score 2.6
Brief criticism:
Relatively unbalanced, does well on dry roadway as well as on snow and ice, but clear weaknesses on wet roadway, particularly in the longitudinal aquaplaning, which leads to the devaluation, well in the wear
Dry: 2.1
Wet: 3.6
Snow: 1.8
Ice: 2.8
Michelin pilot Alpin Pa 2
Rating: * / Score: 2.6
Brief criticism:
Relatively unbalanced, Best score on dry roadway as well as on ice, does well on snow, but clear weaknesses on wet roadway, particularly in the along and transverse aquaplaning, which leads to the devaluation
Dry: 1.8
Wet: 3.7
Snow: 1.8
Ice 2.5
Bridgestone Blizzak LM 22
Rating: * / Score: 2.7
Brief criticism:
Relatively unbalanced, Best score on ice, does well on dry roadway as well as on snow, but clear weaknesses on wet roadway, particularly with the along and transverse aquaplaning, which leads to the devaluation, slight weaknesses also in the rolling friction
Dry: 2.2
Wet: 3.5
Snow: 1.9
Ice: 2.5
Continental ContiWinterContact TS 790
Brief criticism:
Relatively unbalanced, does well on dry roadway and on ice, weaknesses on snow, which leads to the devaluation, weaknesses on wet roadway, particularly in the longitudinal aquaplaning, relatively small external noise
Dry: 2.0
Wet: 3.2
Snow: 2.2
Ice: 2.8
Goodyear Eagle Ultra Grip Gw-3
Brief criticism:
Relatively unbalanced, does particularly well on snow and ice, does well in the wear, but clear weaknesses on wet roadway, particularly in the along and transverse aquaplaning, which leads to the devaluation
Dry: 2.3
Wet: 3.8
Snow: 1.6
Ice: 2.5
Pirelli W 240 Snowsport
Rating: * / Score: 2.8
Brief criticism:
Relatively unbalanced, does well on dry roadway, as well as on snow, but clear weaknesses on wet roadway, particularly in the along and transverse aquaplaning, which leads to the devaluation, easy weaknesses also in the rolling friction, relatively small external noise
Dry: 2.0
Wet: 3.7
Snow: 1.9
Ice: 2.8
1 - 3 of 3 Posts
