Gear shifting (2nd and Reverse)
1 reading
3.3K views 20 replies 11 participants last post by  MarkWeso
#1 ·
Hi all,
Most of the time when I shift from 1st to 2nd or shifting to Reverse, it just doesn't click in smoothly. Its kind of like there is 2 clicks before it goes into that gear (2nd or reverse). It doesn't grind, slip or like there is any noise coming out, its just not smooth like other gears.
2nd to 3rd, 3rd to 4th, 4th to 5th, they just shift in perfect.
Car only have 120km on it, is this normal?
Thanks
#16 ·
The gearbox is essentially the same as previous years, but new for 2015 it has triple-cone carbon synchros for gears 1 & 2, double cone for 3, and single cone for 4-6. It is also fully synchronized for reverse as well, and has been for at least the past 4 years (2011-2014).
I have the Subaru Short Shifter kit, and I have don't have a click per say but when you pull into 2nd for example, there is a small resistance halfway through the shift were it would not be in neutral or in gear, and you have to pull through that to get it actually into gear. I would say it's normal.
#18 ·
The 6 speed in the STi probably has, but the 5 speed in my '13 WRX was definitely not synchronized for the reverse gear.
