GD: ♠♣♦Kartboy, EPIC, HAWK, Carbotech, Whiteline, BC Racing & MORE @ OAKOS!!!♦♣♠
Fast Shipping, Low Prices, Dependable Service. We deliver performance!
Trust our experienced, friendly staff, large warehouse, and years of service experience
to help you reach all of your performance goals!
Why Buy From OAKOS?
Lowering Springs
Coilovers
Strut Bars & Chassis Bracing
Suspension Arms, Links & Accessories
Brake Rotors
FRONT ROTORS
FRONT BRAKE PADS
REAR BRAKE PADS
Stainless Steel Braided Brake Lines
Speed Bleeders
Brake Fluid
Master Cylinder Braces
Other Brake Products
Why Buy From OAKOS?
- STi "Group N" Front Strut Top Mounts, '93-'07 Imprezas (All)
- STi "Group N" Rear Strut Top Mounts, 2004-2007 WRX & STi
- STi "Group N" Pitching Stopper, WRX & STi
- STi "Group N" Heavy Duty Transmission Mount, WRX & STi
- Subaru (OEM) Eccentric Strut Bolt (Front), '05-'07 STi
- Subaru (OEM) Strut Mounting Bolt (Not eccentric, Lower Front / Both Rear), '02-'07 WRX & '04 STi
- Subaru (OEM) Rear Suspension Lateral Link w/ Bushings (Front Link, Left or Right), '05-'07 STi
- Subaru (OEM) Rear Suspension Lateral Link w/ Bushings (Rear Link, Left or Right), '05-'07 STi
- Subaru (OEM) Rear Lateral Link Nut (For Long Bolt), '02-'07 WRX & STi
- Kartboy "Botox" Subframe Lockdown Bolts, WRX & STi
- Kartboy Long Exhaust Hangers
- Kartboy Front End Links,'02-'07 WRX Sedan & '04-'07 STi
- Kartboy Solid Rear End Links, STi FXT LGT
- Kartboy Solid End Links, Front & Rear COMBO
- Kartboy Pitching Stopper Mount
- Kartboy Rear Differential Bushings
- Kartboy Shifter Bushings, Subaru 6-Speed
- Kartboy Rear Shifter Bushing
- Kartboy Transmission Crossmember Bushings
- Epic Engineering Lowering Springs, 2005-2007 STi
- Tein S-Tech Springs, '05-'07 STi
- Tein H-Tech Springs, '05-'07 STi
- RaceComp Engineering "Black" Lowering Springs, '04-'07 STi
- Eibach Pro-Kit Lowering Springs, 2004-2007 STi
- BC Racing "BR Series" Coilover Kit, '02-'07 WRX, '04 STi
- BC Racing "RM Series" Coilovers, '02-'07 WRX & '04 STi
- BC Racing "ER Series" Coilovers, '02-'07 WRX & '04 STi
- BC Racing "BR Series" Coilover Kit, '05-'07 STi
- BC Racing "RM Series" Coilovers, '05-'07 STi
- BC Racing "ER Series" Coilovers, '05-'07 STi
- Tein "Street Basis" Coilovers, '02-'07 WRX & '04 STi
- Tein "Street Basis" Coilovers, '05-'07 STi
- KW "Variant 1" Coilovers, '05-'07 STi
- KW "Variant 3" Coilovers, '04 STi
- KW "Variant 3" Coilovers, '05-'07 STi
- Tein "Super Race" Coilovers, '02-'07 WRX & '04 STi
- Tein "Type HG" Coilovers, '02-'07 WRX & '04 STi
- Tein "Type Flex" Coilovers, '02-'07 WRX, '04 STi
- Tein "Super Race" Coilovers, '05-'07 STi
- Tein "Super Street" Coilovers w/ Pillowball Upper Mount, '05-'07 STi
- Tein "Super Street" Coilovers, '02-'07 WRX & '04 STi
- Tein "Type Flex" Coilovers, '05-'07 STi
- Tein "Basic" Coilovers, '05-'07 STi
- Tein "Type HG" Coilovers, '05-'07 STi
- Tein "Mono Flex" Coilovers w/ Pillowball Upper Mount, '02-'07 WRX & '04 STi
- Tein "Mono Flex" Coilovers w/ Pillowball Upper Mount, '05-'07 STi
- Tein "Super Street" Coilover Front Pillowball Upper Mount, '02-'07 WRX
- A'PEXi N1 Type EXV Coilovers, '02-'07 WRX & '04 STi
- A'PEXi N1 Type EXV Coilovers, '05-'07 STi
- Whiteline 22mm Adj. Front Sway Bar, '02-'07 WRX Sedan & '07 STi
- Whiteline 22mm Adj. Front Sway Bar, '04-'06 STi
- Whiteline 22mm Adjustable Rear Sway Bar, STi
- Whiteline 22mm Front Sway Bar, '02-'07 WRX Sedan & '07 STi
- Whiteline 22mm Front Sway Bar, '04-'06 STi
- Whiteline 22mm HD Rear Adjustable Sway Bar, 04-07 STi
- Whiteline 24mm Adj. Front Sway Bar, '02-'07 WRX Sedan & '07 STi
- Whiteline 24mm Adj. Front Sway Bar, '04-'06 STi
- Whiteline 24mm Front Sway Bar, '02-'07 WRX Sedan & '07 STi
- Whiteline 24mm HD Rear Adjustable Sway Bar, 04-07 STi
- Whiteline 24mm HD Rear Sway Bar, 04-07 STi
- Whiteline 27mm Adj. Front Sway Bar, '02-'07 WRX Sedan & '07 STi
- Whiteline 27mm Adjustable Rear Swaybar, STi w/ OE endlinks
- Whiteline 27mm HD Rear Adjustable Sway Bar, 04-07 STi
- Whiteline Adjustable Rear Control Arms (4), 2004-2007 STi
- Whiteline Adjustable Rear Control Arms WRX & STi
- Whiteline Anti-Lift / Caster Kit ALK (Comfort Version), WRX & STi
- Whiteline Anti-Lift Kit (ALK), WRX & STi
- Whiteline Caster Adjustment Kit (Race), 2002-2007 WRX & STi
- Whiteline Caster Adjustment Kit, 2002-2007 WRX & STi
- Whiteline Com 'C' Front Upper Strut Mounts, WRX, STi, FXT, & LGT]
- Whiteline Front Camber Plates (RACE), WRX & STi
- Whiteline Front Camber Plates (Street), WRX & STi
- Whiteline Front of Rear Diff Support Lock WRX & STi
- Whiteline Front Roll Center Adjustment Kit
- Whiteline Front Strut Tower Brace STi & WRX w/ Large TMIC l]
- Whiteline Front Swaybar Bushings, WRX & STi
- Whiteline H.D. Rear Swaybar Mount Kit, '02-'07 WRX & STi (New Design!!)
- Whiteline H.D. Steering Rack Bushings, '02-'04 WRX & '04 STi ]
- Whiteline HD Steering Rack Bushings, 2005-2007 WRX & STi
- Whiteline HD steering Rack Bushings, 93-2001 Impreza
- Whiteline Heavy Duty Gearbox Mounts (RACE), WRX & STi
- Whiteline Heavy Duty Gearbox Mounts, WRX & STi
- Whiteline Rear Strut Tower Brace WRX & STi
- Whiteline Spherical Rear Sway Bar End Links, '04-'07 STi
- Whiteline Toe Lock Kit, WRX & STi
- TiC Shift Linkage Bushings, '04-'05 STi
- TiC Shift Linkage Bushings, '06+ WRX & STi (6MT & 5MT)
- TiC Race Rear Diff Bushings, '02-'07 WRX & STI
- TiC Comfort Rear Diff Bushings, '02-'07 WRX & STI
- TiC Wide Shift Lever Pivot Bushings, '02-'07 WRX & 08+ WRX/STI
- TiC Shift Lever Pivot Bushings, '04-'07 STI & 08+ STI w/ SS
- TiC Lateral Link Bushings Kit, '97-'07 Impreza
- TiC Trailing Arm Bushings (Front), '97-'07 WRX & STi
- TiC Trailing Arm Bushings (Rear), '97-'07 WRX & STi
- TiC Master Cylinder Brace, '02-'07 WRX & STi
- TiC Front Control Arm Rear Bushing (FCAR), '02-'07 WRX & STi
- TiC Fender Cowl Braces, '02-'07 WRX & STi
- Replica STi Rear Strut Tower Brace
- STi Lower Arm Bar, '02-'07 WRX & STi + '04-'08 FXT
- Perrin Front Strut Tower Brace, '02-'07 WRX & '04-'07 STi
- Whiteline Rear Strut Tower Brace, '02-'07 WRX & '04-'07 STi
- Whiteline Front Strut Tower Brace For Large TMIC, '02-'07 WRX & '04-'07 STi
- SPT Lower Subframe Brace, '02-'07 WRX & STI
- GTSPEC Trunk Floor Reinforcement Brace, '02-'07 WRX & STi
- GTSPEC 4 Point Ladder Brace, '02-'07 WRX & STi & FXT
- Cusco Power Brace (Rear Floor), '02-'07 WRX & '04-'07 STi
- Cusco Rear Subframe Power Brace (Lower Bar), '02-'07 WRX & '04-'07 STi
- Cusco Power Brace (Rear End, Sedan), '02-'07 WRX & '04-'07 STi
- Cusco Power Brace (Front Member), '02-'07 WRX & '04-'07 STi
- Cusco Power Brace (Center Floor, M/T Only), '02-'07 WRX & '04-'07 STi
- Cusco Front Lower Arm Chassis Bar, '02-'07 WRX & '04-'07 STi
- Cusco Rear Aluminum Strut Bar (Oval Shaped Bar), '02-'07 WRX & '04-'07 STi
- Cusco Front Aluminum Strut Bar (Oval Shape Bar), '02-'07 WRX & '04-'07 STi
- Cusco Rear Aluminum Strut Bar (40mm Tubular), '02-'07 WRX & '04-'07 STi
- Cusco Rear Aluminum Strut Bar (Carbon Fiber Bar), '02-'07 WRX & '04-'07 STi
- Whiteline Adjustable Rear Control arms, 2 Links, '02-'07 WRX & '04-'07 STi
- Whiteline Adjustable Rear Control Arms (4 Links), '04-'07 STi
- Cusco Adjustable Rear Lateral Link Kit, '04-'05 STi
- Cusco Adjustable Lateral Links (Rear, Front Position), '02-'07 WRX & '04-'07 STi
- Cusco Adjustable Lateral Links (Rear, Rear Position), '02-'07 WRX & '04-'07 STi
- Cusco Rear Trailing Arm, '02-'07 WRX & '04-'07 STi
FRONT ROTORS
- DBA "Street Series" Front Rotors (Slotted), '04-'13 STi
- DBA "Street Series" Front Rotors (Drilled & Slotted), '04-'13 STi
- DBA "4000 Series" Front Rotors (Slotted), '04-'13 STi
- DBA "4000 Series" Front Rotors (Drilled & Slotted), '04-'13 STi
- DBA "5000 Series" Front Rotors (Slotted), '04-'13 STi
- DBA "5000 Series" Front Rotors (Drilled & Slotted), '04-'13 STi
- Centric "C-TEK" Front Rotors (Pair, Blank), '05-'14 STi
- Centric "Premium High Carbon" Front Rotors (Pair, Blank), '05-'14 STi
- Centric "C-TEK" Front Rotors (Pair, Blank), '04 STi
- Centric "Premium High Carbon" Front Rotors (Pair, Blank), '04 STi
- EBC "UPR Series" Front Rotors (Plain, Pair), '04 STi
- EBC "GD Series" Front Rotors (Drilled & Slotted, Pair), '04 STi
- EBC "USR Series" Front Rotors (Slotted, Pair), '04 STi
- EBC "UPR Series" Front Rotors (Plain, Pair), '05-'14 STi
- EBC "GD Series" Front Rotors (Drilled & Slotted, Pair), '05-'14 STi
- EBC "USR Series" Front Rotors (Slotted, Pair), '05-'14 STi
- DBA "Street Series" Rear Rotors (Slotted), '04-'07 STi
- DBA "Street Series" Rear Rotors (Drilled & Slotted), '04-'07 STi
- DBA "4000 Series" Rear Rotors (Drilled & Slotted), '04-'07 STi]
- DBA "4000 Series" Rear Rotors (Slotted), '04-'07 STi
- Centric "C-TEK" Rear Rotors (Pair, Blank), '04 STi
- Centric "C-TEK" Rear Rotors (Pair, Blank), '05-'07 STi
- Centric "Premium High Carbon" Rear Rotors (Pair, Blank), '04 STi
- Centric "Premium High Carbon" Rear Rotors (Pair, Blank), '05-'07 STi
- EBC "UPR Series" Rear Rotors (Plain, Pair), '04 STi
- EBC "GD Series" Rear Rotors (Drilled & Slotted, Pair), '04 STi
- EBC "USR Series" Rear Rotors (Slotted, Pair), '04 STi
- EBC "UPR Series" Rear Rotors (Plain, Pair), '05-'07 STi
- EBC "GD Series" Rear Rotors (Drilled & Slotted, Pair), '05-'07 STi
- EBC "USR Series" Rear Rotors (Slotted, Pair), '05-'07 STi
FRONT BRAKE PADS
- Carbotech Front Brake Pads, STi Brembo Calipers
- Hawk Front "HPS" Brake Pads, '04-'13 STi
- Hawk Front "Perf. Ceramic" Brake Pads, '04-'13 STi
- Hawk Front "HP Plus" Brake Pads, '04-'13 STi
- Hawk Front "Blue 9012" Brake Pads, '04-'13 STi
- Hawk Front "HT-10" Brake Pads, '04-'13 STi
- Hawk Front "HT-14" Brake Pads, '04-'13 STi
- Hawk Front "DTC-60" Brake Pads, '04-'13 STi
- Hawk Front "DTC-70" Brake Pads, '04-'13 STi
- EBC Front Brake Pads (Redstuff), '04-'14 STi
- EBC Front Brake Pads (YellowStuff), '04-'14 STi
- EBC Front Brake Pads (BlueStuff NDX), '04-'14 STi
REAR BRAKE PADS
- Carbotech Rear Brake Pads, STi, EVO 8/9 & 350Z Brembo Calipers
- Hawk Rear "HPS" Brake Pads, '04-'13 STi
- Hawk Rear "Perf. Ceramic" Brake Pads, '04-'13 STi
- Hawk Rear "HP Plus" Brake Pads, '04-'13 STi
- Hawk Rear "Blue 9012" Brake Pads, '04-'13 STi
- Hawk Rear "HT-10" Brake Pads, '04-'13 STi
- Hawk Rear "DTC-60" Brake Pads, '04-'13 STi
- Hawk Rear "DTC-70" Brake Pads, '04-'13 STi
- EBC Rear Brake Pads (Redstuff), '04-'14 STi
- EBC Rear Brake Pads (YellowStuff), '04-'14 STi
- EBC Rear Brake Pads (BlueStuff NDX), '04-'14 STi
- Goodridge SS Braided Brake Hose Kit, '02-'07 WRX & STi
- Goodridge Brake Hose & Speed Bleeder Combo, '02-'07 WRX & STi
All other Brake parts
- Speed Bleeder, Set (4) - '97-'10 Imprezas
- Speed Bleeders, 2004+ STi (Set of 8 Bleeders)
- Speed Bleeder, Set (6) - StopTech Calipers
- Speed Bleeder, Set (4) - Wilwood Calipers
- ATE TYP200 DOT 4 Racing Brake Fluid (Amber)
- Motul RBF 600 DOT 4 Brake Fluid
- Subaru (OEM) Brake Fluid
- GrimmSpeed Master Cylinder Brace, '93-'07 WRX & STi
- Perrin Master Cylinder Support Brace, '02-'07 WRX & STi
- Motive Products Power Bleeder, WRX, STi
- OAKOS Brake Bleeding Catch Bottle
- Subaru (OEM) Brembo Seal Kit (Front), '04+ STi
- Subaru (OEM) Brembo Seal Kit (Rear), '04-'14 STi
- Subaru (OEM) Brembo Caliper Bolt, Front 2004, 2006-2007
- Subaru (OEM) Brembo Caliper Bolt, Front 2005
- Subaru (OEM) Brembo Caliper Bolt, Rear
Feel free to Pm, Email, or Call us anytime!
