Year:2005
Make:Subaru
Model:WRX
Mileage:102000 M
Transmission:Manual
Engine:2.5L 4-cyl Turbo
Trim:STi
2005 Subaru WRX STi
Price: $22,000
Mileage: 102,000
Transmission: 6MT (manual)
Pictures: see links at the bottom of this post
Description and Mods:
  • mods detailed below and in my build thread.
  • drives great, very responsive, very mean, lots of fun. could use a good bath and a clay bar, haha.
  • motor built by Outfront Motorsports. internals detailed below.
  • originally tuned by Ron Watson/PhatBotti, dialed in by Taylor'd Tuning. built for E85, but conservatively tuned on 93oct around 375WHP and 350TQ.
Problems: paint is sun-faded on some areas of the hood and trunk, speaker amp needs a new fuse, normal dings
Contact Info: brandon65[at]gmail
Current mods (power):
  • Blouch Dom 2.5xtr turbo (10cm)
  • 73mm short ram intake + K&N filter
  • AVO turbo inlet
  • APS dr525 FMIC
  • Turbosmart re-circ BPV
  • 2.5i NA intake manifold
  • KSTech 19mm phenolic spacers
  • Injector Dynamics 1000cc fuel injectors
  • AEM 340lph fuel pump, hard-wired for constant voltage
  • Outfront Motorsports fuel rails
  • Fuelab fuel pressure regulator
  • Fuelab in-line fuel filter
  • Braided fuel lines + AN fittings
  • Perrin divorced catless downpipe (ceramic coated)
  • Grimmspeed ported/coated exhaust manifold
  • Grimmspeed coated hi-flow crosspipe (heat wrapped)
  • Grimmspeed coated catless uppipe (heat wrapped)
  • Cobb catback exhaust
  • Cobb AccessPort v2 (pro-tuned by Taylor Curtis at Taylor'd Tuning)
  • Grimmspeed EBCS
  • Crawford air/oil separator
  • Mishimoto X-Line radiator
  • AEM wideband gauge + logging cable
  • new Subaru oil pump
  • Gates Racing timing belt & water pump kit
  • Torque Solution timing belt guide
  • Killer B oil pickup & windage tray
  • new spark plugs & fuel filter as of Summer 2022
Motor internals & heads, assembled by Outfront Motorsports:
  • CP pistons
  • Manley Turbo Tuff i-beam rods
  • OEM crank
  • King main & rod bearings
  • ARP head studs
  • GSC valves (stainless intake; super alloy exhaust)
  • GSC valve springs, titanium retainers, guides, etc.
Current mods (suspension/wheels/drivetrain):
  • Competition Clutch stage 2 clutch
  • Perrin shifter bushings
  • Cusco front strut bar
  • BC BR coilovers
  • Whiteline tie rod ends
  • GTSpec ball joints
  • Kartboy endlinks
  • Enkei RPF1 18"x9.5"
  • spacers, extended studs, etc.
Current mods (misc/dressup):
  • Killer B alternator shroud
  • ixiz hood lifts
  • Cobb turbo heat shield
  • custom hoodliner
  • Mishimoto power steering & coolant reservoirs
  • front lip
  • limited lip spoiler
  • custom bumper trim
  • WRX side skirts
  • WRX all-black interior
Current mods (audio):
  • iPad head unit
  • Hybrid Clarus woofers
  • Hybrid Legatia L1 tweeters
  • Morel SC-2 sub
  • Memphis Audio amps
  • Clarion equalizer
  • RAAMaudio sound deadening
  • [the Memphis speaker amp needs to be repaired, possibly just a new fuse, but I won't be able to demo the audio as a result]
Why I'm selling:
To be honest, I just don't drive the car much any more. I loved it for many years and spent a lot of time, money, blood, sweat, and tears taking care of it. I did most of the mods myself, with the help of a few expert shops & tuners along the way. I have a few other cars now, and it's time for the STi to go to a new home who will appreciate her like I did for so long. The built motor only has about 10k miles on it and is solid as a rock. NEVER TRACKED - NOT ONCE. I most recently put it back on the dyno in June 2022 - zero issues. I hope someone can give this car a good home and drive it like it's meant to be driven.
These pics do not show the current sun-fade of the paint on the hood & trunk. I will snap some new photos and add them to the listing soon.
