1 - 2 of 2 Posts
2015 Subaru STI
Clean Title with No Accidents
Color:
CWP
Price: $29,000 -> $28,500 -> $27,750
Contact:
2onefive-sixzero1-6six0seven or charly.joung (at) gmail.com
Chassis Mileage: 46,333 and slowly increasing
Motor Mileage: ~30,000
Exterior Condition: 9/10
Interior Condition: 9.5+/10
Overview: Car runs beautifully and smooth. Perfect daily driver with a **** ton of power. If you have an insatiable hunger for more power, you can easily slap on a bigger turbo and get it re-tuned.
New brakes and rotors front and rear.
Mint condition ESR SR08 wheels in 18x9.5.
Reason for selling: Straight up? I'm too old for this ****. It's too loud, ride is too stiff, tired of a manual transmission, and it's honestly way too much power for me. Heck, first thing I did to this is swap the trunk with the huge wing with one with a lip. I've aged/matured enough to know that I want a stock, automatic 340i (if you have one to trade, holla!).
Mods
Head
  • GSC 33mm (+1mm) o/s exhaust valves
  • GSC 37mm (+1mm) o/s intake valves
  • CNC valve seat porting
  • 1-step colder spark plugs
Block
  • CP Pistons 99.5mm - coated
  • Carillo Pro-SA Rods 3/8 WMC Hardware
  • ACL Race Bearings with coating - rod set
  • ACL Race Bearings with coating - main set
  • ARP Head Studs
  • Subaru smooth timing belt idler
  • Killer B Ultimate oil pickup tube
  • Killber B Baffle windage tray
Transmission
  • ACT HD clutch kit - 515TQ
Intake
  • Perrin FMIC kit with tubing
  • Cosworth tumbler delete housings
  • Torque Solutions air pump delete plates
  • Perrin 2.4" turbo inlet hose
  • Perrin air/oil separator
Exhaust
  • Cobb 3" downpipe
  • Perrin equal length header
  • Perrin catback exhaust
Turbo
  • Blouch Dominator 1.5XT-R 8cm
  • GrimmSpeed boost solenoid
  • Perrin turbo heat blanket
  • DEI header wrap - titanium
Fuel
  • Deutschwerks 65C fuel pump
  • Deutschwerks 1000cc EV14 fuel injectors
  • Cobb STI fuel pressure regulator kit
  • IAG fuel rails and hoses
Brakes
  • Centric High Carbon Plain 125 Series Rotors
  • Hawk HPS Brake Pads
Misc
  • Hella Horns with SubiSpeed bracket and harness
Cobb Accessport V3 - Dyno Protuned on 93 - 390WHP
1 - 2 of 2 Posts
