I've got a question about front mount intercoolers... How are they better (or not) than the top mount variety? I figure the first bennifit has to be the lack of huge hood scoop (although I've grown to like it). Also, I guess you can force air through easier (or is that any different considering the enormus volume of the STi's scoop should be able to direct a healthy quantity of air at similar pressures). On the other hand, a top mount IC keeps the total volume of air between the turbo and intake manifold to a minimum, which makes it easier to build and keep pressure higher (both desireable bennifits of turbo's, I would think). Other than the sight of the scoop (which again, I kind of like), I don't see the motivation to change.
