check your oil dipstick.
I did before turning it on the first time and it was sitting right at the f markcheck your oil dipstick.
After I noticed it still did it for another couple minutes till I decided to turn it off and on again, also im not quite sure what you mean by there being dew this morning sorry but I did noticed that the inside of the muffler is quite wet so maybe it is watet just turning into vapor by the heat of the exhaust? I sure hope soIt could just be some condensation inside the exhaust. was there dew this morning?
Edit: how long did it persist?
Thinking condensation inside the exhaust pipe, since when it's not running moisture filled air can get into the exhaust. hence if there was dew on the ground then there will be condensation in your exhaust. sorry should have clarified :lol:After I noticed it still did it for another couple minutes till I decided to turn it off and on again, also im not quite sure what you mean by there being dew this morning sorry but I did noticed that the inside of the muffler is quite wet so maybe it is watet just turning into vapor by the heat of the exhaust? I sure hope so
Sent from my SGH-M919 using Tapatalk 2
