1 - 3 of 3 Posts
Hey guys,
The FP Green 8CM is back!!
FP GREEN 8CM, Helix 860cc Injectors, Cobb AP super Combo!
-FP Green with larger 8CM housing
-Helix 860cc Injectors
-Walbro Fuel Pump
-Cobb AP 2004 STI only
$2499 Shipped!!
Add $50 for other cars
Add $100 for all other Drive-by-wire cars (2005+ STI, 2006 WRX)
Oil / Water lines additional $75
Hey guys we just got in a large shipment of JDM EJ25 engines today! We have:
EJ25 Legacy Turbo Engine
-Virtually identical to USDM STI 2.5 Engine
-Less than 10,000km on engine
-Includes intake manifold, cam gears, sensors, water/oil pump, semi complete engine
-Leak down tested, At least 88% compression across all cylinders (factory is 80%+)
-Awesome for WRX engine swaps
$3499 + shipping
EJ25 Legacy Turbo Long Block Only
-Long Block Only
-EXCELLENT Compression, 93+% compression across all cylinders! (factory is 80%+)
-Crank position sensor holder is damaged, will require fabrication or will work with aftermarket crank position sensor (such as Motec, Tec III, and other stand alone ECUs)
$2599 + shipping
2006+ Plastic Coolant Reservoir
-Lighter plastic construction
-Used
$60 shipped
GREDDY EVO 2 Exhaust for STI
-High Flow Design
-50 State Legal
-Best balance between power and excessive noise!
$569 Shipped!!
Gruppe-S V2 Header
- 4-1 Investment Cast Collector
- NO low-end loss on 2.5 cars
- Gains of over 20 ft/lbs seen on modified STI's!
$399 Shipped!! (4 pcs left)
Please give me a call if you have any questions or would like to order. Thanks!!
Randy
[email protected]
510-783-5300
evilSTi7 said:
what kind of power do you guys generally see with the 8cm green's?
On the 8CM usually an extra 3-5whp on pump 91, and 5-10whp on race gas, without a huge negative change in spool up. :)
Cheers,
Gary
Gruppe-S
1 - 3 of 3 Posts
