1 - 10 of 10 Posts
I have assembled my Ohlins Coilovers, but at the moment I'm having a hard time torquing the locknut on the rear assembly. Says to torque to 30Nm (22ft/lbs.). I have a crows foot on a torque wrench and using a flat blade screwdriver to hold the shaft, as the manual states. I can't for the life of me get the torque wrench to click while trying to hold with a screwdriver handle. You can't overcome the torque while gripping a round handle. I found some hex keys that fit in the groove, but they are so thin, that they just bend before 22ft/bs. is achieved.
There must be a trick, or people are just tightening as tight as they can manage...
I don't understand why they don't just machine wrench flats on the top of the shaft like almost every other manufacturer does...
i think most are just using air impacts on them...maybe grab a second pair of hands to help hold the screwdriver...
Not a solution, but adjust the torque value for the crows foot at whatever angle it is.
I think most people just give it a quick brap with an impact gun. Maybe needle nose vice grips could work.
Impact probably isn't the best idea for both achieving proper torque and not damaging the seals from spinning the shaft.
Much easier to put an allen socket ($5 tool) on the torque wrench and use a box/crescent on the nut. Small cost for expensive coilovers.
Discussion Starter #9
Not sure if you read my original post, but there is no hex interface. It's a straight slot cut into the top of the shaft for a screwdriver. Shitty design, but that's what's there.
Road and track, not TTX, right? They must have changed the design. Mine had a 5 or 6mm Allen. Well, that would make things challenging.
1 - 10 of 10 Posts
