1 - 2 of 2 Posts
Could i fit a set of advan rs's in 19x9" size but with a 38mm (largest avalible) offset? and if so could i run i wider tire (245/55/65) or would i have to run something smaller (225/35) because of this offset?
-Skippy
I Solve Problems
why do you want a 9" wheel?
and do you know the +38mm clears brembos?
you're not going to be able to run those with a stock suspension. they will stick out even with -2.0 degrees camber.
do you really want 19s? if your dead set on 19s, i'm 100% sure we can find some that are the right size/offset to where you can mount a reasonable size tire and not have too many rubbing issues.
are you dead set on the Advan RS's?
what is your current/desired suspension?
are you comfortable with doing body modifications to help fitment?
what is the max camber you want to run in the front/rear?
is this street or track only?
1 - 2 of 2 Posts
