1 - 11 of 11 Posts
Whent to the track last night for the first time and here's what happen
run 1 run 2 run 3
60.- 1.992- 1.956- 1.899-
330- 5.847- 5.795- 5.795-
1/8- 8.998- 8.931- 8.805-
MPH- 77.92- 78.98- 79.47-
1000- 11.693- 11.623- 11.465-
1/4- 13.971- 13.896- 13.729-
I need to learn how to drive my shifting was so bad.
MOds. Cobbs stage 2 with stock catback. perrin drop in filter.
yes shifting is def key, launching helps tho to, eh iight 60' but should be down with 1.7's or 1.6's. my best time with my stock sti was a 13.1 at 104.75 with a 1.6 60'
WOW great times. I know was getting better but with every run but had to leave the track early. anyway I'm hook, I'll be back.
how did u do ur launch?
Thanks man, yeh as you go back you'll get the hang out and and learn the car more, with your mods you should be in the 12's easily
It seems alot of time is killed going from 4th to 5th, what's the secret to getting a fast shift there?
the secret is to learn how to drive the car better, end of story. just make a verry quick shift. i know its not good to do, but wont hurt of you only do it at the track. keep pressure against the shifter like youre going to 5th, and as soon as you puch in the clutch, itll pretty much just know to go there. plus, what are you shifting at. most people are saying around 6400 is best. and how are you running a cobb stage 2 with a stock exhaust?
I've got a MadDad v2 downpipe going to a Stromung Intermediate to a ScoobySport axleback. Thanks for the tip on 4th to 5th, I'll work on that.
I want to 2nd the comment about putting pressure on the shifter before depressing the clutch. This is KEY. I can't imagine pulling off super fast shifts without doing that, it just goes and it's almost as if there was no shift at all.
Discussion Starter · #10 ·
Well i have the stock catback with a catless DP. I shift as follows
first - redline
second 7000
third 6500
fourth 7000
^According to the SP Calculator, you should shift at the following:
1st-2nd-7000 (Redline)
2nd-3rd-6800
3rd-4th-6600
4th-5th-6900
5th-6th-6500
1 - 11 of 11 Posts
