1 - 15 of 15 Posts
Banned
Feal 441 Coilover Kit-$1350 for most model Subaru's
Feal:
We have successfully created a coilover solution that is very well priced and offers unsurpassed performance. The Feal 441 Coilover is a one-way adjustable monotube damper equiped with a genuine Japanese Swift spring. We are confident that our valving profile will yield a very comfortable yet great performing ride for your car. We have spent countless hours testing and are pleased to offer the Feal 441 Coilover kit to you.
The listed spring rates are model and make specific and are designed to work well for both daily driving as well as occasional track days. You can choose different rates and different damper valving to suit your needs.
The Feal 441 Coilover kit allows your car to run either at stock height or as a super low setting via independent height adjustment.
Specs/features:
- One way adjustable, 30 click spectrum
- Monotube
- Japanese Swift springs
- Assembled in house, U.S.A.
- Rebuildable and revalvable in house, U.S.A.
- Independant height adjustment
- Teflon injected spherical bearing top mounts front and rear (MacPherson applications)
- Aluminum top mounts
- Camber adjustable front top mounts (MacPherson applications)
- Slotted rear coilover mounting hole for camber adjustability (MacPherson applications)
- Corrosion resistant coating + Anodized aluminum parts
- High quality low friction seals and rod guide bushings
- High flow pistons (allows super high range of damping tuning)
Click on the model in the table for pictures
Chassis Year Front Rear Camber Plate Notes Price
SUBARU
Impreza, GC 93-01 7k 4k Front Rear camber adjustability provision $1350
Impreza & WRX, GD 02-07 7k 5k Front Rear camber adjustability provision $1350
WRX STI, GD 04 7k 5k Front Rear camber adjustability provision $1350
WRX STI, GD 05-07 7k 5k Front Rear camber adjustability provision $1350
WRX GE/GH 08+ 8k 8k Front $1350
WRX STI, GR 08+ 8k 8k Front $1350
BRZ 12+ 7k 6k Front $1350
1 - 15 of 15 Posts
