I’m transferring over these post from another forum/format and aren’t caught up to current events yet with my STi. I used a pyrometer to measure tire temps once I got the suspension where I wanted it and the temp is pretty even with the insides showing slightly higher with -2 degrees on the front. Which is contrary to what the corprate knowledge seems to be of -3 degrees. Maybe it’s something about my setup or perhaps the local autocross course, but I’ll test it more and make sure my measurements are accurate. I’ll get my post updated and you can tell me what I’m doing wrong haha.I'm in SCCA STU in a 2006. While the bushings are all nice as is corner weighting, the big gains come from struts and alignment. And seat time, get as many runs as you can! And get faster people to show you what the car can really do and to give you advice.
The Bridgestones are still very competitive especially after having a few heat cycles. With your later chassis you might not need as much negative as I do, but if you're going for max handling you will get best handling from a setup that will give you more than -3 camber. Depends on your spring rates, bar sizes, etc. and how grippy a surface is at your racing site.
Get a cheap infrared temp reader (~$30 at HF, a little more elsewhere) and check your tire temps after you come in from your second run. Check outside, middle, inside, immediately on getting stopped, particularly on the front. If the outside edges remain consistently hotter, then you probably need more negative camber. Run zero toe front and rear if it's your daily so that you don't chew up the tires with the big camber.
I have heard positives about Racecomp. I am trying out another brand & builder to replace my less reliable than I'd like KW v3's, but they won't be in for a couple of weeks so I can't comment yet.
It's better to NOT go all out on public roads.The Front/Rear Weight Ratio is 58.7%/41.3%. Based on that weight distribution I calculated the ideal weight at each wheel:
Front Left= ((% on front tires) x (total weight on both left tires))/100 = 1053 lbs
Front Right= ((% on front tires) x (total weight on both right tires))/100 = 983 lbs
Rear Left = ((% on rear tires) x (total weight on both left tires))/100 = 741 lbs
Rear Right = ((% on rear tires) x (total weight on both right tires))/100 = 692 lbs
If you compare that to what I was able to adjust too, I'm within 13 lbs of perfect weight on each corner. Considering I'm working from my own home made leveling platforms, I figure that's about as close as I can get. In the future I might look for some static weight I can move around to properly balance the car further.
Ride height at each corner measured from the center of the Hub to the fender post cross weighting:
Front Left: 355mm/14 inches Front Right: 355mm/14 inches Rear Left: 351mm/13 7/8" Rear Right: 352mm/ 13 7/8"
The rear heights were so slightly different I couldn't really differentiate in inches, hence the 1mm difference.
I also replaced all the lock nuts on the suspension, since they are only designed to be used once and I had loosened and tightened them at least three times each at this point. It was almost $70 of nuts from the dealer, but cheap insurance for the track. I also replaced the front lower ball joints since everything else is now new in the suspension. The old ball joints were a huge pain to get out, but I guess that's standard for ball joints.
Seat of the pants judgement is that the STi feels better than ever. Very flat in corners with much better roll resistance. Feels very balanced and controllable in corners. It felt like I got a little power on oversteer at one point, but it may have just happened from the undulations in the road causing the rear end to loose some grip. I guess I'll find out at autocross. I wish I had a place to do some objective testing, but I'll make due for now.
After nearly a month of the car spending most of it's time on the lift, it's great to have it back to drivable and feeling better than ever.
Not to fear, I’m a 35 year old man with the means for track days and all the autocross available. At not point do I drive “all out” on public roads. And desptie the interest and attempts, no my local region has not put together a test and tune day due to limited venues and other logistics. There is an ok way to take your car around the block after you install coil overs to check your work and there is a wrong way. I’m mature enough to do it the right way.It's better to NOT go all out on public roads.That's what race courses are for. And it's tough to tell exactly what happens at the limit unless you're somewhere you can exceed it slightly. Our local chapter sometimes hosts a "Test and Tune" day with a short course with a hard left, a hard right, and some slaloms, and more runs, so you can try things out and adjust better outside of competition. See if you can get people enthusiastic about that idea.
Replacing the locking nuts is a good idea. If I don't have the replacement locking nut I will add thread locker during re-assembly.
I don't have my alignment sheet handy but the rear is IIRC about -2. That is a result of the amount of lowering, plus the KW's have a slot in the top attachment point to the hub that allows some additional camber to be subtracted. The rear does not max out in the normal usage, cornering force wise, the front is still my limiting factor on my GD chassis. The fronts gather a lot more heat and pressure build at events, so they are obviously doing most of the work. With the new coilovers I'm going more radical on the rear spring rates and planning to drop the rear sway bar adjustment back. I get some oscillation in corners on throttle that I suspect is partly because the inside rear is lifting off the ground, spinning up a little, then upsetting the chassis when it comes down as I apply power. The new setup is /supposed/ to use the helper or tender springs to keep the tire on the ground more, and backing off the sway bar should allow the spring to set the tire down better. I'll see.
As I said the balancing is good for final trimming. I'm on the large side so getting the car corner weighted means more adjustment. My rears, sitting on my not really even driveway, are at 13" hub center to fender left and 13.5" right, but because of the pavement I'm not sure if that is really meaningful. It's lower than yours but I'm not sure if the numbers transfer between chassis families. For the new coilovers I'm obviously going to have to align and corner balance again. I may bump the front height up a little to increase clearance to the fenderwell liners because I keep destroying those, even with 255's which are about all that fits into a GD fenderwell. This loses me some negative but as I am also bumping the front bar size up on advice of a local suspension guru. That may limit the travel a little more and allow liners to survive, or even allow me to go to a slightly larger width as the RT-660's are available in 275.
