1 - 8 of 8 Posts
Hey all, been on IWSTI for a few years but never did a build thread so here goes..:
My 2011 OBP STi Sedan
I started going the "track/autox" route..like everybody else...
(random event photos)
My autox attempt
Everybody was doing the autox thing, all the same mods were being installed as everyone else..so I decided to go a completely different route and went show..
Mod list:
It all started with bushings.. to keep the warranty, then an AP, cus y’know, it’s like putting just the tip in.. then…warranty is over rated…? uckfay it, I’m goin’ for broke!
ENGINE
AEM Cold Air Intake
Invidia Catless 3" Down Pipe
Invidia Q300 3" Cat Back Quad Tip Exhaust
Cobb Access Port
Dyno Tuned at Lightspeed 294awhp 345awft/lbs torque
RA Motorsport Turbo Heatshield
Perrin Rad Shroud
Perrin Boost Cover
Perrin Alternator Cover
Project Kics Magnetic Oil Drain Plug
0AWG Grounding Wires
Optima yellowtop battery
SUSPENSION
Airlift Performance air suspension (BC Racing struts with double bellow front and bag over strut rear)
Airlift Performance AutoPilot V2 digital controller
RaceComp Engineering 25mm Sway Bars (front and rear)
Whiteline Adjustable Sway Bar Endlinks (front and rear)
Whiteline Rear Lower Control Arms
Whiteline Rear Adjustable Toe Arms
BRAKES
DBA4000 Slotted Rotors (front and rear)
Hawk HPS Performance Brake Pads (front and rear)
Technafit Stainless Steel Black Coated Brakelines (front and rear)
ATE Super Blue Racing Brake Fluid
DRIVETRAIN
Kartboy Pitch Stop Mount
Perrin Subframe Lockdown System
Perrin Differential Lockdown System
TWM Short Shifter
TWM Front and Rear Shifter Stay Bushings
WC Lathe Werks Stainless Steel STi Sphere Shift Knob custom powdercoated black
EXTERIOR
Varis Carbon Fiber Lip Kit
Seibon CW Carbon Fiber Hood
Aerocatch Hood Latches w. Password JDM Backing Plates
Seibon Carbon fiber Trunk
Project KICS license plate bolts
APR GTC300 Carbon Fiber Wing
HT Auto Grill
Blacked Out Tail Lights
LED Rear Brake/Tail, Turn and Reverse Light Bulbs
JDM R205 Black Side Badges
WSC Rear License Plate Frame
OE fog lights with 5k LED bulbs
Morimoto 35 5k HID's
Hella Supertones in Red
Diode Dynamics Stage3 LED front turn signals
DRL delete
FAST WRX LED flasher
Custom blacked out headlights
Kinda hard to see but you get the idea
These do not emit coloured light, therefore technically they are legal. You will only see the red if light is shining INTO the projector as just the front of the cutoff shields are painted.
TSXR lenses, flattened squirrel finders and washer mod
JDM Rear Fog Light
WHEELS
Originally, I wanted black EVERYTHING. Including these:
But, price played a bit of a factor (Volks right?..sheesh), and after months of googling pics of black on black, I found that unless you get the EXACT same black as the body color it wont look perfect in my eyes. So I opted for the matte bronze instead. And in my opinion, it was the way to go.
18"x9.5" +38mm offset Work Emotion Kiwamis in Matte Bronze
265/35r18 Bridgestone Potenza RE-11's
Project Kics REVO Neo Chrome Racing Composite R40 Wheel Nuts
INTERIOR
SMY ClusterMaker Dual 52mm Gauge Pod
Defi Red Racer 52mm Boost Gauge
Defi Red Racer 52mm Oil Pressure Gauge
Custom 52mm A-Pillar Gauge Pod
AEM UEGO Wideband AFR Gauge
JPM Coachworks Italian Leather Black with Red Stitching Shift Boot
JPM Coachworks Italian Leather Black with Red Stitching E-Brake Boot
Bride Gias LowMax driver Black with Red Stitch Reclining Seat
Bride Stradia LowMax passenger Black with Red Stitch Reclining Seat
Bride Seat Rails
Takata Drift III harnesses
Blackvue DR500GW dashcam
WeatherTech digital floormats
DAMD JDM D-shape steering wheel
Dynamat lined trunk
Motec Cree LED Interior, Trunk and License Plate Lights
I’ve also painted all the silver trim in the center black. I wanted more of a uniform color.
5% tint on rear, 35% on front
Before tint:
After tint:
The tint was a uckfaying nightmare. uckfay you Clear Choice Auto..
http://www.westernsubaruclub.com/smf/index.php?topic=22698.0
I.C.E.
Pioneer AVICX-930BT In Dash Touch Screen DVD/NAV
Alpine Type R components front
Paranoid Fabrications speaker spacers
2 x Alpine Type R 10" dual voice coil subs 1000w rms each
Audison Quattro Voce 4 ch amp
Custom sub enclosure built by Powersource Performance
0awg Amp Wiring Kit
I like it loud..Orion amp shown here but that one kept overheating, so in went an Audison amp.
I know there’s more mods but I can’t remember them. Ill update as I remember..
Parts sitting around:
DW65C fuel pump
Killer B oil pickup and baffle
Custom diffuser from Evilsubiecustoms
A crying credit card
I’ve done all the work myself, minus the dyno tune and exhaust install. Had that done in one shot at Lightspeed because I don’t have a dyno. And the trunk setup was done by Powersource Performance.
Had a bit of a bum fight to get this plate authorized.. I put in the request and received a letter a few weeks later stating that they had denied my application because of what I wanted..Im assuming they thought it was some sort of sexual reference haha. I emailed the DMV twice and plead my case, assuring them of what the acronym stood for.. they eventually overturned their decision and sent me the plate!
And for shits and giggles..
1 - 8 of 8 Posts
