1 - 3 of 3 Posts
I have an 05 STI and was wondering what i need to goto cobb stage 2, is it just the ap and the tbe??? Also in order for the ap to work will i need the tbe before i map?
Sorry...i know noob questions suck
Yes all you need is the Cobb AP and a TBE, and yes you should install the exhaust first and then flash the ecu immediately afterwards. If you do drive the car without the Cobb stage 2 map installed make sure to take it easy until you can flash it. Without the Cobb stage 2 map installed, you risk hitting boost cut sooner and running into a lean condition.
^^^ i think its actually just the other way around. since the boost cut level is raised, you have more of a chance of running lean, then you do stock. thats my thinking.
1 - 3 of 3 Posts
