1 - 4 of 4 Posts
Good morning,
I found IMO the perfect fitment. I saw it however on a 15+ WRX, 18x10 +38 with tire size, 255/35. Anyways, I was wondering if someone can tell me if that will clear our Brembos?
Thanks in advance guys!!!
Yup it will. I own an ‘18 STi and it clears the 6 Piston Brembos without any issues. If you drive a previous year’s model, the 18x10 +38 offset will likely clear its Brembos too. Tire size may be a limiting factor in having the proper fitment though. 255/35 is a pretty narrow tire for a wheel that’s 10” wide. While 275/35 is the ideal size to run, I’d recommend going 265/35 at the very least.
I'm not sure if a 18x10 +38 will fit without rubbing though. You might have to roll your fenders. especially with something like a 275 on them.
18x10 +38 on a 15-17 STi needs at least a 3mm spacer up front. I run a 5mm spacer with extended studs. Also 275/35 re71r’s, coil overs and I rub slightly in the rear. Fender roll should fix that. It did not rub on stock suspension
1 - 4 of 4 Posts
