1 - 20 of 126 Posts
Vendor
We here at OAKOS carry every suspension bit you need for you GR. We carry endlinks, bushings, Anti-Lift Kits, sway bars, differential bushings, control arm bushings, when I mean everything, I mean everything. We also have a very nice selection of Enkei and Prodrive wheels. From Enkei, we carry the RPF1, GTC01, NT03+M and many more! From Prodrive we have the GT1 and GT2's!!
Now to introduce you all to our Whiteline, Perrin and Cobb products. From Whiteline, we offer a whole assortment of bushings, sway bars and lowering springs. From Perrin, we offer the large 25mm ADJ. Front sway bar and endlinks! Also, we carry their Positive Steering Response System!! Cobb offers you GR guys their Sport Lowering Springs, 25mm front sway bar and rear adj. and their double adj. short shifter.
Perrin Positive Steering Response System
  • Replaces the front lower control arm mounts with a solid connection
  • In turn we offset the bushing to provide added caster, and anti-lift features
Whiteline Anti-Lift Kit (ALK), 2008 WRX & STi
  • Increasing caster helps to reduce front end lift under hard acceleration which keeps the front end planted when powering out of a turn.
  • The stiff bushing helps to reduce deflection of the control arm which leading to better alignment settings and increased response.
Whiteline Subframe To Chassis Inserts, '08+ WRX & STi
  • Sub-frame To Chassis Inserts.
  • Allows a more positive feel from the back end during cornering.
Perrin Adjustable 25mm Front Sway Bar, WRX & STi
  • Adjustable ends allow the customer to fine tune the sway bar based on daily driving requirements using any of 2 possible end link positions.
  • Will produce better cornering, reduced body role and greater control over your suspension.
COBB Rear Sway Bar, 2008 WRX (5 Door Only) & STi
  • Increase spring-rate of 230%, 350%, & 535% over the OEM sway bar with the adjustable mounts.
  • Chromoly splined bar is black zinc plated
    Anodized aluminum arms.
Perrin Front Sway Bar End Links
  • With a static radial load resistance to 13,250 lbs these bearings are virtually indestructible.
  • PERRIN™ end links are precision cut from virgin aluminum ensuring strength, durability, and crisp sway bar response providing maximum performance and feel from your rear sway bar.
Whiteline Rear Sway Bar End Links, 2008 WRX & STi
  • Increase rear sway bar response.
  • More precise handling.
COBB Sport Lowering Springs, 2008+ STi
  • 10% stiffer in the front & 20% stiffer in the rear
  • Reduces front and rear ride height by 7/8"
Eibach Pro-Kit Lowering Springs, 2008 STi
  • Lowers the front approximately 1.0" and the rear 1.0"
  • Reduces understeer, body roll and body pitch
Whiteline "Control" Spring Combo, 2008 STi
  • Whiteline's "Control" series of springs are designed for performance street use. For race track use check out Whiteline's "Flat Out" series of springs.
Almost all orders placed before NOON EST. will be shipped!! 99% Guarantee!! If you have any questions or would like to place an order our number is 866.97.OAKOS(62567) and our office hours are 10am-4pm EST. Monday-Friday!!
Vendor
We just cut prices on all Prodrive GT1 wheels!! Now's your chance to get some extremely strong, light weight wheels!! These wheels are setup JUST for Subaru's!! They are hub-centric and run the perfect offset!!
STi Fitment
Prodrive GT1 Wheels (18x8.5", 5x114.3), Matte Anthracite (Save $128!!)
Prodrive GT1 Wheels (18x8.5", 5x114.3), Gloss Anthracite (Save $128!!)
Prodrive GT1 Wheels (18x8.5", 5x114.3), Gloss Black (Save $128!!)
WRX Fitment[/COLOR]
Prodrive GT1 Wheels (18x7.5", 5x100), Gloss Black (Save $116!!)
If you guys/gals have ANY questions, feel free to give us a ring and our Prodrive specialist Sean will gladly help you :D Email - [email protected]
Office Number - 866.97.OAKOS (62567)
Office/Warehouse Location:
44019 Phoenix Drive,
Sterling Heights, MI 49314
Bart
OAKOS Automotive
Vendor
We have TONS of SILVER Enkei RPF1's IN STOCK!
  • 18x10 +38 5x114.3 - Silver
  • 18x9.5 +38 5x114.3 - Silver
  • 18x10.5 +15 5x114.3 - Silver
  • 18x10.5 +15 5x114.3 - Matte Black
  • 18x9.5 +15 5x114.3 - Silver SOLD OUT!!
  • 18x9.5 +15/18x10.5 +15 5x114.3 Staggered - Silver.
Enkei RPF1 - EVO 8/9 and X
http://www.oakos.com/Merchant2/merchant.mvc?Screen=CTGY&Category_Code=20999
Enkei RPF1 Wheels (18x8.5", 5x114.3, 30mm Offset) Silver
Enkei RPF1 Wheels (18x8.5", 5x114.3, 30 offset) Matte Black *Limited Edition*
Enkei RPF1 Wheels (18x10", 5x114.3, 38 offset) Silver
18x9.5 +15/18x10.5 +15 Staggered
Enkei RPF1 Wheels (18x9.5", 5x114.3, +38 offset) Silver
Enkei RPF1 Wheels (18x10", 5x114.3, +38 offset) Silver
Enkei RPF1 Wheels (18x10.5, 5x114.3, +15 offset) Silver
Enkei RPF1 Wheels (18x10.5, 5x114.3, +15 pffset) Matte Black *Limited Edition*
Some may require spacers, all require hub-centric rings (CB on 350z 66.1mm - CB on RPF1 73mm)
Here is a picture of how many we have in stock...
18x9.5 +15 Silver/18x10.5 Silver staggered available!! 18x10.5 +15 Matte Black and Silver available!!
The FREE Muteki Spline Drive Lugs are only available on IN STOCK orders and are your choice of open or closed ends and they come in black, chrome, silver, blue or red. (silver closed end is sold out!)
We can get ANY WHEEL that Enkei makes!! We stock the RPF1, NT03+M, RS03, GTC01 and the RS+M!!
OAKOS Enkei Wheel Selection
Here is a full line up of Enkei Wheels:Call us at 1-866-97-OAKOS (62567) or PM us to get the deal on the FREE Center Caps!
Please feel free to ask us any questions on here via PM or email us at [email protected].
Email me directly at [email protected] with your wheel inquires!!
Bart
OAKOS Automotive
Vendor
Discussion Starter #7
Bump for Thursday!
Orders placed by NOON tomorrow are almost guaranteed to be shipped same day!! We offer FREE shipping on almost everything!!
Bart
OAKOS Automotive
Vendor
Discussion Starter #10
In 18x10 the only color currently available through Enkei is Silver, if you step it up a notch to 18x10.5, there are more colors available.
We are expecting more wheels from Enkei around late May.
Bart
OAKOS Automotive
Vendor
Discussion Starter #14
Up to the top for the end of the week.
As always our website is open 24/7 to take your order.
All PM's will be answered first thing Monday.
Have a great weekend!!!
Bart
OAKOS Automotive
Vendor
Discussion Starter #16
1 - 20 of 126 Posts
