1 - 20 of 20 Posts
My 05 has been making alot of noise coming from the rear in the past 2 days. today i checked out the rear suspension to see if i could find anything wrong (I thought it was the rear strut noise) but to my suprise the endlinks are bent to ****. Its so bad the the links are rubbing the lateral arm and have even engraved it real bad. My question is this, what could have caused this?? I have 4300 miles on the car and i have been dropped w/gf210's for about 2k and i never noticed anything. Will the drop cause the links to bend?? also do u guys think my dealer will warranty this since its dropped?? i hope so, it only has 4k. LMK what u guys think. Thanks
also i noticed that the endlinks sit under the bar, isnt it suppose to on top??
Convoy said:
anybody??
Oh yeah. The stock endlinks are garbage for the rear. I recommend Kartboys. They will keep your sway from flipping. The fronts SHOULD be ok. I had my sway bar flip after I upgraded to pinks and bigger sways.
Oh yeah and your bar sounds like it's flipped. Get the links fast. :)
do u think my dealer will warranty them, i dont have the cash right know, i can however get them in 2-3 weeks
+1 for garbage stock endlinks. Don't even bother getting them waranteed 'cause they'll bend again, unless you REALLY can't manage the money for the KB's.
yea i cant manage it right now, i can order them in about 2-3 weeks but i need to fix this ASAP so im planning on taking it to the dealer tomorrow. hopefully they warranty them
if at somepoint you lifted one of the rear wheels off the ground going over a bump or even when lowering the car down from a jackstand it can cause your swaybar to flip and bend the endlink. not sure if subaru will warranty them, it's probably a crap shoot.
wow! I keep hearing about this but it hasnt happened to me. Are the links aligned correctly at rest? I have COBB swaybars and Cusco Zero 2R coilovers and track my car regularly with no issues. I love bouncing onto two wheels and the stock endlinks are still working fine after 18K miles.
Being lowered, i doubt that the dealer will help you. My dealer wanted to void my entire warranty due to a COBB heatshield, they didnt even notice the DP!
What makes KB's better? Just stronger or some kind of better geometry etc?
MUCH stronger (like, its funny to see the KB and stock side by side), plus a little longer than stock to combat the tendency to flip the sway.
Discussion Starter · #12 ·
well the dealer said that the endlinks arnt covered by the warrany because they arnt suppose to bend on themselves. they said that the only way that it could have happened was if i hit something that made them bend. they only cover defects. I told them that those tiny endlinks were bending left in right in the subby comminity and he said that this was the 1st case he'd ever seen. bottom line subaru warranty is a joke. I just picked up a pair of whitline links and i will replace them tomorrow.
well you don't want stock endlinks anyway, it will happen again.
get kartboy endlinks. trust me same thing happened to me and im so glad that i got the kartboy ones
Discussion Starter · #14 ·
yea, i picked up a set of whitlines endlinks and they look 100x better then the stockers
You're better off with the aftermarket E/Ls anyway, but if that happens again call SOA. Its often not Subaru's fault, but individual dealers being jackasses. Some dealers are great about warantee coverage.
1 - 20 of 20 Posts
