I'm pretty much a noob so bear with me...
I had my whiteline 22mm fixed front sway mars installed on my 05 wrx sti and I've been hearing rubbing ever since. Recently I put the car on the lift checking for bad cv joints an other mishaps and then found the evidence of some grinding. I turned the wheels and come to find out the end of the sway bars right at the corner where the bars meet the links it connects with the toe adjustment rod (not sure if that's it's real name) and grinds across as the steering continues until it locks. It does this on both side. Again I'm pretty new to this and I'm not entirely sure what would be a good way to fix this issue. Grind Dow the bars corners a couple mms to help it clear? Maybe my bar is installed wrong? Maybe I need different length links? Someone help
its been going on for a couple months and it definitely shows on the hardware. Btw I believe the links are still the stock links. I'll upload pictures when I can. I'm starting this thread on my iPhone and please don't bash me if this thread is already up or I'm in the wrong place for this. It's my very first post.
