1 - 20 of 22 Posts
I also have a stock 04 STi shortblock, low compression but good candidate for a rebuild, cylinders in good shape.
Looking for $450, feel free to offer
Could also separate crank/rods if wanted.
Crank: SOLD
Rods: $100
Case: SOLD
This block is out of a 2004 Java Black Pearl STi. Located in the Detroit area. For pictures or inquiries, you can PM me or for fastest response, text me at 24824zero19zero9
Would you happen to know if the crank is the same for 04-18 sti? im really interested in it. Thank you
Yes and no. The cranks are the same in the EJ25s as in, you can use any year crank. However the new cranks are nitrated while the old ones are not, which means different main/rod bearings are used. As long as you use the correct bearings with the correct crank, there will be no issue
Discussion Starter #7
Bump! Quality OEM parts for cheap. STi rods are good for 500 at the wheels, so all you need is some machine work and forged pistons for a solid setup!
1 - 20 of 22 Posts
