1 - 8 of 8 Posts
I just got my block :D. It is an ej22t block that has been sleeved and bored. It was build by Howard at Arfabriaction.com. What’s inside you ask? Darton sleeves, Cp pistons, Crower rods, Total Seal rings, Cometic head gasket, and ARP case bolts to hold it all together. Here are a few pictures, just a litter teaser more on the way. I want to give Howard a special thank. If any one need a motor, I highly recommend Arfab.
I love the EJ22. Great work by the way.
Thanks every one, I will keep you updated on the project. Howard thanks for the tip about the table. And thank you for all your work that you did on my motor. The block is alot stronger because it’s close deck. As far as displacement goes it's a 2.6L. 100mm bore with 79mm stroke.
1 - 8 of 8 Posts
